Adam Berti
As a side note, probably redundant. But use caution with adding a 20 amp *breaker to a series of outlets that were previously on a 15 amp breaker. I'm not familiar with code standards, but I'd imagine the wire gauge will need to be sized up from the breaker for 20A.
This is a really important piece of information to be aware of. The breaker is sized and designed to protect the wire. So a 15 amp breaker will ensure that the wire going to the receptacle does not overheat and start a fire if the device at the other end pulls too much power. You cannot just replace that 15amp without knowing what wire is going from the breaker to the receptacle. Code is different in different jurisdictions, but usually a 15amp receptacle will have only 14 gauge wire but a 20 amp breaker will needs 12 gauge to operate safely.
