That's great that it worked out!
What inverter did you use?
Fwiw, some hybrids can have the 12V battery spike a little for a very short time, while the high voltage battery pack is charging the 12v battery. That can trip the input over-voltage protection on some inverters.
Some other tips:
A 2-gauge, or thicker, wire should be use. It has to be connected directly to the battery.
Make sure the inverter is not in a closed space (inside the vehicle, under the hood, in the trunk, etc). The inverter needs to cool itself.
The electric motors on things like refrigerators have a
very high initail current draw. If an inverter isn't sized correctly, it will trip and turn off the inverter from too high of a load.
To be safe, I
strongly suggest a
Pure Sine Wave inverter. That's especially true for items that have motors, like a refrigerator, small AC unit, etc.
Some suggestions for inverters:
My main suggestion is a top quality inverter, that also costs like one.
https://www.amazon.com/dp/B004L08GME/
Magnum Energy MMS1012
Price: $761
1000W 12V Inverter, MFG# MMS1012, pure sine wave inverter providing a cost effective solution for smaller power needs in mobile applications, 1000W continuous power, 12v, 120VAC @ 60Hz.
Specs:
http://www.magnum-dimensions.com/file/2157/download?token=s7nyXLxB
NOTE: This inverter can be both an inverter and a battery charger. This way, someone could have a bank of batteries, and this would keep the batteries charged. Then, when main AC power is lost, it would enable the 12v to 120V inverter. Typically, that inverter output would go to a separate breaker, or a transfer switch.
So, with a battery like the following:
https://www.amazon.com/dp/B01KN7K48W
Renogy Deep Cycle Pure Gel Battery 12V 200Ah
Price: $438.92
You a person would have 24 kWh vs the Clarity's 17 kWh.
However, unlike the Clarity, a person could
not start the engine and/or drive it to get more gas to charge the batteries.
Another inverter that is popular with the hybrid crowd,
https://www.amazon.com/dp/B000C73A3K/
Aims 1000 Watt Pure Sine Power Inverter 12 VDC to 120 VAC USB Port ETL Listed to UL 458
Price: $198.66
1000 Watt continuous and 2000 Watt surge
Pure sine wave perfect for all equipment up to 8.3 amps
ETL Certified to UL 458 Standards
Over load, temp, circuit protections and low battery alarm
I hope the above helps.
