Clarity_Newbie
Anyone use fumoto valves on their Clarity or Honda vehicle? I've read on some Honda vehicles the oil drain plugs are recessed thus requiring an adapter.
Thoughts?
Thoughts?
Just bought one on Amazon, I'll find out Saturday if it fits.
My bad. Hadn’t been on their site in a while. The Clarity is now listed on their pull down menu options. It’s the F106 Series. I’m going to lift And use jacks to see which one will fit the best.I’ve used those in every car I’ve owned and told my son to put one in my Christmas stocking. I found the Clarity uses the standard size for all Honda’s. The Clarity is not listed on their website but just plug in (bad pun) an Accord and order that one. Don’t know about our Claritys needing the adapter, but my CR-V didn’t need one. As long as there is room to rotate it tight with the small lever protruding to the side you’re go to go. I’ll use the nipple with a length of tubing to make sure no oil spills on the underbody to the front of the removable panel.
PS: I’ve never had one leak and boy howdy does it make oil changes easier. Well worth the price for those of us who change their own oil, even though now I’m only doing so once a year.
When I win the lottery, I’ll have a grease pit out in my garage because why not spend tens of thousands of $ to save $10 on your oil change.
Based on a lot of late night Goggle-fru on many sites, forums, and blogs, the general consensus seems to be that Honda uses regular oil with no additives for factory fill (FF). The FF oil can appear darker because of the assembly lubricants used on various parts. They get diluted into the normal FF oil as the engine runs, so it’s practically the same effect as adding “break-in” additives to the FF oil.I still can't see Clarity on the Fumoto website.
Not sure what I am doing wrong, but I can't even pull up 2018 model year search.
I picked the same F106 series you (Ken) recommended based on Honda Fit 1.5 liter.
My dilemma (that only occurred to me after I received the valve) is that since I just changed O/F, I have to choose between capturing oil in a fresh pan and re-using it or grabbing another 3.5 qts.
btw, the oil was pretty nasty looking at 6K miles, so I didn't feel bad about changing it (no analysis or accuracy to that statement, just eyeballs).
Full disclosure: there is the possibility that Honda additives for factory fill made the oil look dark.
Thanks for this. Any photos you could share with it installed?It is said that the better part valor is discretion and the better part of discretion is patience, that patience is a virtue and the foundation of virtue is humility.
That being the case I have to humbly admit that, lacking the above qualities in any measure, I just couldn't wait till the next oil change to install the drain valve.
Requires a 17mm wrench and 18 foot pounds to install.
The F106SX fits with clearance to spare with the valve pointing down, but other angles will also work.
I wanted best drain path with least horizontal distance.
An adapter would be needed for some clock positions that regrettably I forgot to note.
Most positions are fine with no adapter.
Straight down is interesting because there is a hole in the engine bay shield placed just right for connecting a hose.
Obviously, that won't help unless there is a way to change the oil filter with the shield in place, but there is the cool factor of everything lining up.
If you get an SX series like I did, be aware that you need a snap on nipple *if* you want to add a hose (not necessary for me).
The integrated nipple is probably too short to hold a hose securely (haven't tried this).
The valve comes with a security clip that I don't think will be needed based on experience with my Prius, but is added security.
Thank-you Ken for the drain plug cross-reference info, without which I would not have made the purchase!
@Atkinson, I’m glad you couldn’t wait because now I know for sure it fits the slightly recessed area without needing adapters (didn’t want to wait but also didn’t want to have to pay 2 shipping charges if I needed an adapter). Just ordered mine and spent a dollar on the little black cap for the outlet (not really needed, but why not). I have the plastic nipple and hose left over from a Tacoma but I don’t think it will be necessary. The 90 degree clockable design gives a strait shot down on the SX, but I bet it drains slightly slower.It is said that the better part valor is discretion and the better part of discretion is patience, that patience is a virtue and the foundation of virtue is humility.
I should have, but I was trying to get the job done before my wife got back from her friend's house.Thanks for this. Any photos you could share with it installed?
@KentuckyKen, did I miss your post of your oil analysis?Sorry for the late reply. First oil change in Feb at 1 yr and 7672 miles as prompted by the MM. I only had about 700 miles in HV and only 12.6 hours of ICE operation. So I’m greater than 90% EV and the ICE has had very little usage but I’m obeying the all powerful MM to keep the Honda warranty gods happy if I ever have an ICE related claim.
I installed the F106SX so thoughtfully documented by @Atkinson and @V8Power above. I just got so excited, that I forgot to take pictures and post.
I suggest the newer model F106SX over the F106N because
1. It seals with o-rings and not by a washer between it and the oil pan.
2. It lets you swivel the outlet port to any position very easily. (Straight down easy to achieve; see @V8Power’s pix)
3. It’s only $4 more.
Only downside is that you will need a torque wrench to properly install to 18 ft/lbs.
Also, buy the SH-10 straight socket for $1 at the same time if you do want to attach a vinyl tube to the short valve nipple. It snaps on and it makes it a lot easier. It takes 1/2” OD (3/16” ID). You don’t really need it but I use a short length of tubing to direct the oil into a gal milk jug without splashing. You can buy the tubing by the foot at hardware stores or Fumoto will sell you more than you need for $3.
Except for needing ramps and/or jacks, it’s an easy peasy job. There’s plenty or room after removing the cover. Hardest part of the whole job is remembering where you put the dang socket adapter/tubing from a year ago!
Here’s the socket adapter with some tubing that I use:
Mea culpa. I’ll check on that and will post in this thread.@KentuckyKen, did I miss your post of your oil analysis?
