That looks nice but since it needs to be formatted FAT32 I think you will only be able to use 32 Gig of the 128 Gig.i bought this. Can almost close the usb port cover over it, but not quite.![]()
Samsung 128GB USB 3.0 Flash Drive Fit
Yeah, and why Honda couldn't provide 2-amp USB ports or at least two 1.5-amp ports instead of one 1.5-amp port and one 1.0-amp port. Wait, I figured it out--powerful ports would have reduced the car's EV range (riiiight).Speaking of USBs. Does anyone find it odd that the USB ports are upside down???
At least on my car, the “top” of usb plug in actually needs to be pointed down.
Bothering my OCD.
I have one of these plugged into a USB port in my wife’s 2016 Pilot. It’s formatted FAT32 and has the whole capacity available. The aggravating part is Honda’s infotainment system in that car limits the size of individual music files so that some are too big to play. The system also resets to the first song anytime you turn the car off while connected to it. Picks up where it left off only if you change the source before shutting the car off and then pick it as source again when you restart.That looks nice but since it needs to be formatted FAT32 I think you will only be able to use 32 Gig of the 128 Gig.
FAT32 means 32 bits, not 32 GB. FAT32 can make a 16 TB filesystem with 4k "sectors", you just have to not use artificially-limited Microsoft tools to format it. Even Windows will read and write from one that's been appropriately formatted, so I expect the car wouldn't have problems with the size alone.That looks nice but since it needs to be formatted FAT32 I think you will only be able to use 32 Gig of the 128 Gig.
Nope, that limitation no longer holds true.That looks nice but since it needs to be formatted FAT32 I think you will only be able to use 32 Gig of the 128 Gig.
That is correct. I use a 64GB formatted FAT32 with an utility I downloaded. It works fine except it is annoying when you have too many nested folders. Subfolders are of no use.FAT32 means 32 bits, not 32 GB. FAT32 can make a 16 TB filesystem with 4k "sectors", you just have to not use artificially-limited Microsoft tools to format it. Even Windows will read and write from one that's been appropriately formatted, so I expect the car wouldn't have problems with the size alone.
I'm sure CarPlay or Android Auto has a better user experience, but maybe it's just me, I just feel the sound quality is better coming from a USB drive.
