Puppethead
So virtual rumble strips! I didn't realize the 2022 LCI came with that feature.I think the steering wheel vibration is well done. It’s a subtle feeling in the steering, but noticeable (a very rapid, but slight, shimmy).
I found I have to use low regenerative braking when I have the dogs as passengers to avoid throwing them around at stop signs; it is pretty weak (some might say smooth). I think I have to take my foot off the accelerator about twice as far away from an intersection as high regen.It's so lame it will feel like your MINI is broken.
Pooch-protection is a good reason.I found I have to use low regenerative braking when I have the dogs as passengers to avoid throwing them around at stop signs; it is pretty weak (some might say smooth). I think I have to take my foot off the accelerator about twice as far away from an intersection as high regen.
I wonder, are there any SE drivers who always use the lower regen braking setting?
Compared to my Bolt, the Mini does a lot to smooth out the transition. The Bolt does exactly what you tell it, which can be jerky until you are used to it. The Mini will smooth some of that out for you, making it a much more enjoyable ride. You don't have to focus so much on foot position.It's basically what "one pedal driving" is all about, but I don't think I've heard/read anyone discuss how the smoothness of transition between acceleration and braking is up to the driver's finesse.
It slows down a lot after 80%. It took me about 20 minutes to go from 80% to 90% the only time I tried a DC charging station. I've read it could take nearly an hour to go from 80% to 100%. However, you're probably not going to be arriving at the EVSE at 0%, so it will take you less than 90 minutes to get to 100%. Those last few % will try your patience to the max.It’s been a few months since I watched SE recharge videos, and I can’t find what I’m looking for. At a DC fast charge does anyone know the estimated time for a full charge, assuming you get the full juice from the EVSE? I know it’s around 35 minutes to 80%. We decided to try a road trip tomorrow - 90 miles each way. There is an Electrify America station at our destination, so I plan to try that. Depending on range remaining when I arrive, I might need to charge beyond 80%.
I recommend cruise control.
I never floored any of my ICE cars the way I do my SE. I hated calling attention to my juvenile behavior when I pushed the pedal to the mat. I floor my SE much more often, believing I am audibly invisible. Maybe when I turn 80 (or collect a few speeding tickets), I'll grow out of it.I used to floor it like an ice
Hi all,
We bought the Mini Cooper SE as a local run around and we love it however due to our ICE car going into the bodyshop for some work and a courtesy car not available I need to do a long trip...
It's 81 miles to the destination and then 8 miles to a Shell Recharge 150W charger.
Planning on getting an 80/85% charge then doing the remaining 73 miles back.
So questions...
- Am I pushing it charging at the 89 mile mark? I'm getting a 100 miles, sometime just over, range with the current weather.
- The journey is all 70mph A-road and Motorway. Do I drive as usual at 70 or should I be doing 60, or less, the whole way?
- Any other tips?
Thanks!
Nick
And how did the car drive, compared to your old 2009 Mini-e? Is there a part of you that would like a connection to that humble beginning, or have you mostly moved on?You should be able to do it if you keep your speed at or below 70mph. I drove a Cooper on an 1,100-mile road trip and I charged every ~85 miles or so.
Check out the post: https://insideevs.com/reviews/410446/video-mini-cooper-se-1111-mile-trip/
