electriceddy
Moderator
Very well done , thanks for the link.This thread seems to get fairly sporadic traffic, but maybe it's the best place
to put this ... the button shifter is a pretty stupid design, and like in other
prior-art setups, the Park button should have been placed farther away
from where we can keep hitting it by mistake. I decided to fix mine.
That page also indexes into a growing set of fixes, hacks, explorations, etc
that I've been doing with the car over the last month or so. Still in process...
but it's like the old "tear your Prius apart" days all over again!
_H*
One question, when you pulled the switch panel left side of the dash, you said the VESS wiring was there but no button. It is my intention to add a momentary contact switch off pin 7 c/w a 200 ohm 1/4 watt resistor to ground to temp disable the VESS sound as indicated here:
https://www.insideevsforum.com/comm...al-engine-sound-system.5821/page-6#post-78003
(see the link to mikeselectricstuff diagram). Does this make sense to you and is the diagram and wire colors/ pin config the same as your tech manual?
Also how hard was it to pull the lower dash as I can't contorty myself to get under there to remove the switch module.
BTW there is a thread about modifications :
https://www.insideevsforum.com/community/threads/modifications-and-tweaks.5009/
Do you mind adding your link
https://www.insideevsforum.com/comm...dislike-about-the-kona.6079/page-3#post-80335
to this thread as it would be easier to find ,
Thanks... electriceddy
