Your car's climate control is using less (if any A/C) now and not cold enough to use the heater much. But once you get below 40F, you'll notice a diff. Also, colder air is more dense, hence more drag. That however, is more linear and in San Fran you never really get very hot there, or cold, so that also has less effect where you live.How cold does it need to be to make a noticeable difference? Thus far in cool but temperate San Francisco (recent days have had highs around 58-62 and lows in the mid-40s), I've seen no difference at all.
That's definitely hard to test. Since you would have to rule out things like road conditions and elevation changes (going uphill/downhill). But definitely interesting to try.While there is an effect from that, it isn't a strong one. I looked up the density of air at various temperatures:
1.225 kg / m3, at 15 degrees C and at sea level.
1.292 kg / m3, at 0 degrees C and at sea level.
1.367 kg / m3, at -15 degrees C and at sea level.
I have seen various things suggested as to the cause for lower economy in the winter.
My sense (without a lot of evidence of my own) is that it is #3 and #4 that are the big ones. This link suggests that just preconditioning the battery can buy you back a good chunk of the range you lose in the winter:
- Increased rolling resistance from stiffer tires.
- Increased drag from more dense air.
- Increased internal resistance in the battery when it is colder resulting in lower efficiency.
- Use of heater to keep the cabin comfortable.
https://www.greencarreports.com/new...ic-cars-in-winter-tips-from-experienced-owner
That being said, if one were on a longer trip of several hours, the battery pack ought to warm up just from scavenged heat, and the #3 penalty would gradually go away. I haven't been able to do exhaustive tests to try out this theory however. I would sort of want to wait for a really cold day, and then map pack temperature as a function of time once I got on the highway. It just hasn't gotten cold enough here yet to make it worth my while to attempt such a test. And we have a heated garage which complicates matters (I suppose I could just leave the car outside overnight).
Well, like I said, it depends a lot where you live. In a place like Manitoba (APU) 80F in summer and -30F in winter are not uncommon.
-30F or -34C before any adjustment for wind chill effect is down right brutal to even the best ICE vehicles. Fortunately my average winter is closer to -20C with only perhaps 2 or 3 weeks where it can drop into the -30s. If you have the "pleasure" of this experience in a Kona EV you will loose 40-45% of your range, your shocks will stop dampening, tires will be rock hard and your resistance heater will be running at a constant 3+Kw just to keep the windows from completely frosting over. On the upside I love how an EV will more likely start than ICE vehicle in these extremes and doesn't take 5+ minutes for the engine to heat up to get going or provide heat. IMHO, despite the range loss EVs are superior to ICE vehicles in the winter.Well, like I said, it depends a lot where you live. In a place like Manitoba (APU) 80F in summer and -30F in winter are not uncommon. That equates to a diff of 8000 ft in density altitude, and 25% in drag effect. I am a pilot, and for us it is well known that if we fly at 8000 ft, the air is 75% as dense as at sea level (less drag). Here is a density altitude calculator if you want to play around with it. 59F is standard temp and 29.92 is standard air pressure.
http://www.pilotfriend.com/pilot_resources/density.htm
Also your car's rolling resistance incl internal shafts/gears/bearings are also much higher at -30F. Lots working against you in severe cold.
Actually, that is a good point, too, about the loss of range with ICE vehicles.On the upside I love how an EV will more likely start than ICE vehicle in these extremes and doesn't take 5+ minutes for the engine to heat up to get going or provide heat. IMHO, despite the range loss EVs are superior to ICE vehicles in the winter.
I have a very consistent commute and compared warm vs. cold temperature driving:
Actually I didn't use heating at all other than for a few miles when it got really cold in the car. So I used the heated seats (no heated steering wheel) for the whole drive. And I heated the cabin for a few minutes after it just got too cold for me.Perhaps I missed something but did you mention anything about climate control? What I'd like to know is how does temp affect mileage range if climate control is not running? My GOM clearly shows a large difference in estimated range by turning climate control OFF but that's an estimate. Real world performance data is worth having. I suspect there's a "sweet spot" where climate control can be used to "moderate" interior temps and still maintain reasonably good range. When my car begins heating from stone cold the temp always seems to default to something like 75°F, which feels great but is unneeded since I'm dressed for winter conditions. I immediately set it down to around 60° since that is waaaay warmer than the outside 20°F temp. I can see the GOM move up in range incrementally as I lower the climate control temp.
What I'd love to see is a chart that compares measured outside temps to the "set" climate control interior temps with a resulting percentage change in estimated range. That would be really useful.
(Hmm. As I wrote this I suddenly realized it would be possible to do this by sitting in my driveway and recording the estimated range at different interior temperature settings. As a starting point it would be possible to make a baseline for future comparisions. I'll look into this.)
