2020 Clarity, I bought a set of new Michelin X-Ice XI3 this spring, size 235/45R18XL https://www.canadiantire.ca/en/tires/pdp/michelin-x-ice-xi3-tire-0051817p.2085626.html
While I should have done some research about 17 I have the brand new set now. It's about $120 + tax to change it over without rims and $40 with rims here in BC.
I had a hard time finding steel wheels, on Kal-Tire/Canadian tire, pretty much any shop online, even on forums it seems like it's not easy to figure out which wheel would fit. I did find this one here on C-Wheels, just wondering if this would be an exact fit for the tires and for the car. The only spec that looks different is the steel wheel shows offset of 40mm, while stock wheels has inset of 50mm, not sure how those 2 numbers are related
https://www.c-wheels.ca/en/fitments...del=Clarity&submodel=Plug-In+Hybrid&year=2020
Specs:
Item #: 1002398
Diameter: 18
Bolt Pattern (mm): 5x114.3
Offset (mm): 40
Centre Bore (mm): 64.1
Fixation Seat: Radius
Colour: Black
Part #: X48515
Part Type: Steel Wheel
Wheel Weight (lbs):31.8
--------------------- Reference stock wheels I copy and pasted---------------
Enkei alloy 18X8J: 42800-TRT-N90
Bolt pattern: 5-114.30mm
Inset: 50mm
Hub bore: 64.1mm
Trim assembly (plastic): 44733-TRW-N00
Lug nut: 90304-SA0-981
Valve assembly: 08W16-S47-A0004
TPMS Sensor: None
Honda accessory replacement alloy wheel: 08W18-TRT-100
Specs:
Item #: 1002398
Diameter: 18
Offset (mm): 40
Colour: Black
Part #: X48515
Inset: 50mm
Hub bore: 64.1mm
TPMS Sensor: None
