Comments to
@DanGest :
I've found the seats comfortable as they are, but haven't tried a cushion for lower back to see if it is better. Do love the heated seats for my lower back, though. Might try the pillow trick just to see if I've been missing something and not known it.
Never had backup sensors, so don't miss them. I use the camera when I'm close to something.
I'd ignore the manual's "no chains" if I thought I needed the traction. Not a good idea to drive much in chains, but when you need them and feel comfortable installing and removing them, I'd use them. Just check to make sure you have enough clearance with the chains on (could be Honda is worried about the fender when wheel is turned if it is tight clearance). If you feel like it is tight, you could go with slightly smaller tires (of course, that will throw off the speedometer and odometer). Also, the cable type chains might lay closer to the tire if clearance is an issue. If you use chains, don't leave them on longer than you need them, always check for wear after use, and replace as needed. Also, slow down, remember you put the chains on because the roads are slippery. Chains shouldn't give you false comfort with speed. Again, I'd use them if I needed them, but I've never been one to follow rules I don't agree with.
Agree the car is wide. I love it being big. Usually not hard to find plenty of space to park in Alabama (lots here drive big trucks).
Concur that Honda should have given some memory options on both driving mode and regenerative braking in Econ (it remembers in Sport).
Don't miss the volume knob and wouldn't pay another dollar for one. I know that makes me a little of an oddball here.
After driving a first generation Chevrolet Volt, the clearance for the 2018 Clarity is great. But yes, it's lower than some cars. I never scrape the Clarity, but maybe it is because I am used to dealing with the low clearance of the first generation Volt.
Seats fold down, not the best design, but definitely helpful that seats fold down. I generally love the sedan design over a hatchback, but I hear you.
I have free maintenance from the dealer where I bought the car, so not a big deal to change the oil annually.
I agree that I cannot imagine buying another gas only car. Our last gas car is a 2002 Tahoe that we bought new. It refuses to get unreliable and is still in pretty good condition with 230k miles. Still, we spend a lot of time thinking about an appropriate replacement that is primarily or fully battery powered.
