MichaelC
Yes, there is definitely a learning curve when driving EVs, so adjusting how you drive them is the key.
Fossil-fueled cars have so much hysteresis in their drivetrains that you can apply full-on/full-off accelerator inputs and still get smooth outputs. With EVs, there's a much more direct relationship so you have to learn how to apply smoother accelerator inputs to get smoother outputs.
The accelerator pedal on the SE isn't a binary "I want to go" input; it's more like a continuous "how much I want to go" input. If you want to go "less fast", apply less accelerator--but don't let off completely, because that signals "I want to stop going". Once you have adjusted your driving style with that understanding, you can improve your skill by learning how to modulate the accelerator so the car coasts in the "Ready" zone (between accelerating and regen braking regions) when you are at your desired speed, adjusting the accelerator slightly as needed to speed up/slow down while cruising (which improves efficiency).
