BACKGROUND
About three months ago I fell against the J1771. The next morning I found the car had not charged; the plug was at an angle because the latch tooth had broken off. It would still charge our cars but the proximity sense did not work unless I manually remembered to push the latch.
A couple of weeks ago, I bought a replacement J1771 connector from Amazon and installed it on the BMW L1 charger.
Survey Replacement
The first step is to disassemble the replacement. It came in without any instructions so this assumed some degree of understanding.
The shell is held together by Torx screws that were easy enough to remove:
Inside we find a the push button lever that activates a micro switch. This is part of the proximity sense circuit the car uses:
The plug is sealed using triangle screws. So I went to my favorite hardware store and bought a tri-wing bit which worked close enough for this first attempt:
So here is the shell, plug, and plug cover:
With the switch not activated, we measured 150 ohms:
Activating the switch, the resistance increases to 479 ohms that signals the car should stop charging. This avoids "hot" plug and unplugging that can lead to connector wear from small arcing:
Here are the parts of the plug:
There are five pins: ground is on the tab side; at the 2 o'clock position is the proximity pin; at 10 o'clock the pilot signal; 5 o'clock is the 'HOT' pin (black wire), and; 7 o'clock neutral:
This shows how the pins fit in the plug assembly:
Here you see all subassemblies together:
I bought a new stripper sized for power cables and a crimper tool. Sad to say, the crimper did not work out:
(continued due to 20 image limit)
Survey Replacement
