Of course this opportunity applies only to US residents but big kudos for documenting that! Clearly consumers can't take control unless they use all the tools made available.
Many owners affected by these problems disappear into the ether once their situation is resolved, leaving all following having to start from scratch. Somehow the concept of how an owner's community works didn't get through.
We have consumer protection laws here in NZ that says a product must last for a reasonable period of time and a few have managed to get Hyundai-Kia to cover at least part of the expense out of our very-short warranty period. However, it's recently been revealed that Hyundai in turn have required them to not publicly disclose the relevant details.
Really appreciate this perspective, and you’re absolutely right about owners disappearing once
their car is fixed. That’s exactly what lets manufacturers treat each case as an isolated “goodwill” favor instead of a pattern they’re responsible for.
On the NZ side, what you’re describing lines up with what I’ve been able to find:
- Under the Consumer Guarantees Act 1993, a vehicle has to be of “acceptable quality,” which explicitly includes being durable and safe for a reasonable period of time, even well outside any written warranty.
- If that guarantee isn’t met, the buyer can insist the dealer/manufacturer remedy it, and if the problem is serious or not fixed in a reasonable time, the remedies can escalate to refund, replacement, or compensation for the loss in value, not just a repair.
- When dealers or distributors refuse to play ball, NZ owners can go to the Motor Vehicle Disputes Tribunal (MVDT), which can order repairs, refunds, or compensation up to $100k.
So in theory, a failed reduction gear / motor bearing on a relatively young EV is exactly the kind of “not durable for a reasonable time” defect the CGA was written for, and it should be arguable even if the formal Hyundai‑Kia warranty has expired.
The part you mention about Hyundai only paying out on the condition that owners
don’t share the details fits a pattern I’ve seen elsewhere: they frame it as a “confidential goodwill gesture” rather than an admission of a systemic defect. That keeps each case siloed and makes it much harder for other owners (or regulators) to see that there’s a common problem and push for a broader remedy.
From my side, I’m trying to push in the opposite direction:
- document everything publicly (TSB numbers, dates, mileages, complaint IDs),
- connect it to the regulatory/consumer‑law tools in each country, and
- leave a clear trail that the next owner can pick up instead of starting from zero.
If you’re comfortable sharing in general terms (without naming individuals), I think even anonymised NZ examples would help other owners understand how to actually
use the CGA/MVDT path rather than just assume “out of warranty = out of luck.”
