All -
I have owned my Clarity for approx 2 1/2 years and over the last year have modified my driving style from starting out in Econ Mode to Starting out in Sport mode, primarily to lock max Regen from the start-up. This leads me to several questions for the more technically-oriented members:
1.) Is there any way possible to re-program the Clarity to start-up un Sport mode, versus having to manually do this.
2.) Even at max regen with a semi-charged battery, the Clarity seems to be programmed very conservatively with respect to its Regen/braking ability. Would it be possible to re-program the Clarity for stronger Regen braking, or is this just a limitation of the generator used in the Clarity?
For reference, I recently test drove a dual-motor Model Y and a Standard Range Model 3 and the Y had much stronger Regen. When I asked the Tesla Rep, they indicated that it was related to the size of the MY motors....leading me to believe this might be the reason for the Clarity Regen limitations.
As always, thank you for your review and reply!
