Recurrent auto
  • Replies Replies 7
Well, maybe, but I’m guessing this is simply calculated or guesstimated, not actually measured.
It is measured. It is done through the same interface as the app. I don't know if the app reads SOH, but the car does.
Recurrent recommends keeping the battery between 30 and 80% SOC. I've seen studies showing EV LiIons have best range life with a 50% DOD. Yes I know mini says just keep it charged, but I'd like to maximise life.
With the battery buffer on my own Mini, that's an indicated 22% to 80% to get an actual 30-80%.
My EVSE can be set for a timed charge. I get 1% charge in 2.7 minutes, so I set according. Though once in the commuting groove, I find I can leave it at 2hr15 and be close. Time at high charge also affects life. I charge right up to usual departure time to minimise that.
I've been doing this maybe a month now. I've discovered that the battery needs a periodic float charge to keep the cells balanced. Just charging to 100% once a week wasn't doing that. Apparently, the i3 will balance the cells after at least 5 hours at 100%.
2 summer commutes is around 55%, I charge every other day
Yesterday in crosswinds from Ian, my commute was 42%. Hmm, I see daily charging in my future.
Did Recurrent indicate that somewhere? I don’t recall seeing any issue with my i3. I kept it at 80% and it always measured at the top of their battery health ranking for similar cars. Granted, someone else owned the car for the first 4 years in a cold climate.
Glad to see that they are now including the SE. I added ours.
No, the float charge info was from a forum post, somewhere. I noticed a slight drop in capacity. This has now been reversed with a couple of good float charges. I'll be trying a 6 hour float once per week now.
