Thanks
@craze1cars. That’s a very informative site and article by Mr Goreham.
It’s common knowledge among the Volt community that their algorithm is set to not allow gas to stay in the tank past one year. However, the verdict is still out on whether the Clarity is set up the same way.
While it does perform periodic System Checks, we do not know if it is scheduling them with sufficient frequency and duration to burn at least 7 gal per year. The manual only says it will keep the engine on until it reaches operating temperature. In contrast, GM clearly tells its owners that the Bolt will burn at least one tank per year.
Posts seem to indicate that ours will not since there are no reports of System Checks/
ICE operation more often than a month or so. My experience is that unintended or uncalled for ICE operation is a rare event on the order of every few months or so (with the exception of the known no regen allowed after full charge scenario where hard braking or large regen will cause it). And in my Clarity it only lasts for 5 min or so. So for me at 11 months, the algorithm is not going to burn off a tank in one year. I drive almost all EV and have taken only 2 trips in HV wirh ibly 12.6 hours on the ICE. It’s been six months since the last HV trip and fill up and I’ve not lost a bar on the gas gauge and the ICE has only come on 3 times for a few minutes each. Only one is those appeared to be a System Check; the other 2 were the no regen allowed after full charge events.
So even though we have a pressurized fuel system that helps keep the more volatile components of gas from evaporating, I am going to avoid ethanol gas and use Stabil until I start doing more HV or we have proof the Clarity acts like the Volt and burns gas before it gets older than 1 year. (And I’m not comfortable with even that level of retaining old gas in the tank)
I’d rather be cautious than sorry later.
But I admit it’s a moot point for most of us that unlike the minority, do drive enough in HV to be fueling every month or two and so don’t have to worry about this.
I currently have a full tank that’s been there for 6 months with <20 minutes of engine operation at idle like speeds and no loss of gas gauge bars. So in my case, it makes sense to me to use some Stabil. It can’t hurt and potentially can help prevent deposits. The trouble is that I can’t know if it did any good until it’s too late to matter. So, better safe than sorry for me.
YMMV
Edited to correct Bolt to Volt. However as
@Robert_Alabama pointed out to me, the Bolt won’t burn a tank of gas in a year either! LOL
