Rear eyebrow removal to add more range
  • Thread starter Thread starter No Ice
  • Replies Replies 32
  • Views Views 3K
What is the consumption label of the toyo CR1 in kona size ?
According to what I find on Google, it's not great, aren't there better tires for consumption ?
The eyebrow may be creating a low-pressure area under it that is sucking up the car's road spray. Or turbulence that is doing the same. Shame the newer Kona's have so many holes showing after the eyebrow is removed, compared to the old Kona in the video in post #1
Yes its a pity about the holes, mine is gray so the black plugs are not so noticeable, i hope, I would like someone to make blank cover to just cover over the holes only ??
these are the tires i will be using ,
caillou
in 225/55R/17 size, as you can see they have MAX efficiency, lots has changed in the tire world in too years
But that scaling is from the manufacturer itself, isn't it?
don't you need a external label comparison to know how it ranks against other brands?
silly me, I thought you would use the master link i sent you with the how to read a label and look up the cr1 in the correct size yourself.
end of my answers than you, and good hunting for your info.
Just trying to help here
I was not able to find the cr1 EU label when you 1st mentionned it, only found the malaysian labels that I shared, which do not point toward best fuel efficiency. However, as you said, there may be a new iteration of this tire with better performance ?
It seems that CR1 is not sold in Europe
"how it ranks against other brands?"
"done that as well"
Could you share the sources of the comparison?
this is what i viewed, having them fitted tomorrow so time and millage will tell. thank for your interest, cost via other spec played a big part as well. as you can see the CR1 is very new to the market, althought from a good brand,
The Toyo Proxes CR1 i have a friend with the nano 3s an as the CR1 is the nano 3 upgrade went with them
Hi, the toyos are fitted and on the drive 95 km home, i noticed they are a LOT quieter than the Khumo,s they have replaced after 50,000 kms
and i am not sure if its the altered track settings or the CR1,s or both as i used about 10%+ less watts per Km-- 136watts pkm at 95kmph avg
