Rear eyebrow removal to add more range
  • Thread starter Thread starter No Ice
  • Replies Replies 27
What is the consumption label of the toyo CR1 in kona size ?
According to what I find on Google, it's not great, aren't there better tires for consumption ?
The eyebrow may be creating a low-pressure area under it that is sucking up the car's road spray. Or turbulence that is doing the same. Shame the newer Kona's have so many holes showing after the eyebrow is removed, compared to the old Kona in the video in post #1
Yes its a pity about the holes, mine is gray so the black plugs are not so noticeable, i hope, I would like someone to make blank cover to just cover over the holes only ??
these are the tires i will be using ,
caillou
in 225/55R/17 size, as you can see they have MAX efficiency, lots has changed in the tire world in too years
But that scaling is from the manufacturer itself, isn't it?
don't you need a external label comparison to know how it ranks against other brands?
