Ready for new tires
  • Thread starter Thread starter Valente
  • Replies Replies 32
  • Views Views 12K
I'd be interested in data about this if you have a source. The greatest difference I've seen reported between tires in mpg (and therefore EV miles) is only in the 3%-5% range. Most tires are in the 1%-3% range or difference.
This might be a bit unrelated to this topic but I lost 10% range when swapping to my winter set of wheels and tires. Pretty much consistent 50 miles EV range to 45 as soon as i put them on.
I say a bit unrelated because winter tires are going to be a bigger hit to range than any of the all season tires you guys are discussing here(maybe not the run-flats). Also I swapped to a 17” rim without those fancy aero covers.
That being said, I agree with you and with my next set of all seasons I will be going with non-LRR tires expecting at most 5% drop in range. Whatever is the quietest tire is more than likely what I’m going to purchase. Bridgestone Turanza Quiettrack?
For me looking at the Bridgestone Driveguard tires they roughly weight 5lbs more per tire. This unsprung weight difference in addition to slightly higher rolling resistance and higher price didnt convince me this time around, but I do recognize the benefits. I am completely happy with the Continental PureContact LS tires.
Since the Clarity does not have a spare, driving on run flats (RFT) is the next best thing to not being to change out a tire.
I have been driving RFT for over 20 years and have to say that the newest generation RFT have improved dramatically.
When it comes time to replace the Clarity tires, I will be looking at WINTER - RFT:
Dunlop
Goodyear
Bridgestone
Pirelli
If dealing with a snowy climate is not an issue and you don't have a need for run-flats, then Michelin has 2 options I think are worth considering. I got the quotes from Tirerack.
View attachment 7210 View attachment 7211
These are specially engineered to be quieter -recommended for Tesla.
IT appears that Michelin has implemented an insert called Acoustic Tech. https://www.michelinman.com/acoustic-technology.html
I'll be replacing my OEMs soon with these Pilot Sport 4 with AT for better handling at the cost of lower tread life with the softer compound @ 320. If tread life matters, then the MXM4 are better @ 500.
Lousy wear rating on the Sport 4.
At 18 months and just under 28M miles I just had the same decision to make. I live in NJ where the weather can be unpredictable (usually some snow but not so much this year!) but really wanted a better handling tire in all weather conditions, without having to change out between winter and summer tires.
I researched several options and the Michelin Cross-Climate+ seemed to be getting great reviews and met my requirements. I first installed them on my son's 2010 Civic (much lighter car) and have been happy with their overall performance, as they demonstrated good traction during an early December snow-storm and have also been good during cold rains this winter as well as dry road handling conditions. Next, my father installed them on his 2006 Acura TL 6 speed (my old car!) and he has been equally satisfied. So last night I had a set installed on the Clarity. Early impressions are good - for me, there is an acceptable trade-off between slightly increased noise for much improved overall grip. They also have a 98 load index 600 treadwear rating so should hold up. Too early to know what the impact - if any - will be on fuel efficiently but will check back in a week after I have had a chance to drive over more varied conditions.
I stopped in to get some ideas on replacement tires and this thread is very helpful. For those of you that have replaced their tires, did you have to do a special kind of alignment? My husband took my car into the dealership for service today and it’s time for the tires to be replaced. The dealership gave him the full spiel on how not only the tires we get will have a big influence on efficiency and smoothness (true!), but that a special “electric balancing and alignment” needs to be done and tire shops won’t be able to do that. That sounds shady to me...Can anyone confirm that shadiness? Thanks!
We have never ever had an alignment done with a tire replacement or rotation. Replacing tie rods, idler arms, front suspension parts - yes. Tires, no.
I never do alignment unless something is wrong with the car, like the steering pulls one way or something like that.
Agreed. That has happened so infrequently for us that I've forgotten doing alignments for that reason.
ClarityPHEVer
Shady doesn't begin to adequately describe that statement.
Based on this one statement...it may be wise to double-check any recommendations coming from that dealership.
Good luck.
There is a lot more to tire choice than size (and speed rating). The Clarity is a fairly heavy vehicle and requires a load index of 94.
OEM tire spec is 235/45 R 18 94V.
94 is the Load Index, V the speed rating (you won't find anything that won't do 80 mph). Higher speed ratings tend to come with other handling benefits.
The Clarity comes with Low Rolling Resistance tires. This trades other performance characteristics for better fuel economy (gas and electric). You'll have to juggle budget with efficiency, ride quality, traction, road noise, etc.
I'd have to second the load rating as an important parameter. Clarity + 4 people + luggage = worst case for sure...could be 5000+ lbs easily.
Consideration's for tire selection are varied and subjective to what is important to an individual.
To each his/her own.
Good luck.
My best tire purchase experience is with Costco. Purchased online, the tires came in a week or so to the warehouse. For tire/wheel combo tirerack is good too, assuming you can mount them yourself.
A friend shipped his TireRack tires to a local Big O and they installed them no problem.
