R1S pre-order
  • Thread starter Thread starter MattD
  • Replies Replies 23
  • Views Views 12K
MattD
Check in if you have. All the buzz around the truck, I wonder how many opted for the SUV. I pre-ordered on January 2.
I am wondering why Rivian would not make SUV on same platform as the pu truck. 135in compared to 121in wheelbase
Most people would prefer more room especially if going camping etc
If Ford uses platform for bigger SUV they will outsell Rivian smaller truck!
Bad business Hmmm
What is your source that most people would want a bigger vehicle for the occasional camping trip? Over say, easier to park, fits in their garage, already carries more than they will utilize 90% of the time, etc?
Bad business Hmmm
I'm pretty sure they're both on the same platform and share a 135.8-inch wheelbase.
R1T does show the 135.8 in (3,450 mm) wheelbase with a 215.6 in (5,475 mm) overall length.
R1S is on a 121 in (3,075 mm) wheelbase and 198 in (5,040 mm) length.
Tow rating is also less on the R1S - 3,500 kg vs 5,000.
R1S has a touch more ground clearance and a greater breakover angle than the R1T
Most people if given choice will chose bigger as there is no fuel penalty for size with electric truck
Also u may be able to sleep in back of 135in model if weather bad
Would prob fit in garage with air suspension lowered
Look at sales of suburban to Tahoe
Shud at least make both
We reserved the R1S because we want a vehicle that is like an SUV we drive now. The R1S will fit in our garage too. The R1T, not so well. Our reservation was acknowledged by Rivian on 29 November 2018.
Wow. I can't believe I hadn't noticed both the differences in wheelbase, but also the overall lengths of the two vehicles. Also just noticed the R1S has 5mm (.2 inches) more ground clearance, which is a pretty minor difference, but still.
So, they've got similar flexibility in their platform as Volkswagen has in its MEB platform (which is to be used for a plethora of different models). Golf clap.
Yes dom
Is there any way of confirming if they plan a Suv on bigger platform?
They say they are planning several models by 2021. I’m interested in 5units but would like bigger truck.
Not much space behind 3rd row in standard SUV
Yes dom
Well, we could ask them if they're planning on a larger SUV. I tend to doubt a larger one would happen within the next few years, though. They have lots on their plate with these first two, and they've said the 3rd vehicle will be a "rally-like car."
That’s unfortunate Dom. Seems it would take minimal engineering as they already have that platform length for pickup. Besides that it covers both ends of SUV segment
They also said want to stay away from car business. Please ask.
I wrote RJ directly about this.
No response
Already placed my "pre-order" (Rivian not accepting "reservations" yet) for the R1S, though the more I learn about the R1T I *may* change it to the R1T when I'm notified to place my order.
Respectively disagree. Unless you're flying in the vacuum of space, bigger means more material; more material means more weight; more weight affects range. Of course the affects on the range will vary depending on the aerodynamics of the "bigger" vehicle, but the range will still be less due to the additional weight.
FWIW, I believe it was R.J. who has stated the R1S will share about 85% of the R1T. I don't recall him going into any detail of that 85% other than to say it will allow them to launch both vehicles at the same time or something to that affect. {WAG ALERT} Perhaps there is something designed into the platform that allows for different wheelbase lengths thus not impacting materials and production line efficiency?
Very little change in range. 10mi as per there estimate
I think you are just going to have to accept that the market research Rivian did about their target audience dictated a smaller SUV than you are looking for (at least in their first models).
There is no one vehicle that is going to satisfy every customer, and your desires seem to fall outside of the demographic they are targeting. At this point, the best you can hope for is a larger variant produced sometime down the road, but that is likely several years away. Or maybe Ford will produce an SUV as well as the F150ish EV they are planning on the Rivian platform?
