Question on buying a charger for Mini in UK
  • Thread starter Thread starter YellowDog
  • Replies Replies 8
  • Views Views 129
YellowDog
My niece in UK after visiting me in Xmas fell in love with my Mini and bought one upon getting home. It surprised me to learn that in UK you are supplied with an adaptor cable (?) and not a plug and charge one like in North America even though it is only a L1 charger. As a matter of fact I am using it since day one for 5 years.
Is it a common practice in UK such that the owner need to buy their own charger?
Level 2 AC charging in the UK is mostly untethered..aka Bring Your Own Cable. It's less of a charger, and more of an L2 extension cord (Type 2 to Type 2)
Hi the best home charger i have found if you have solar is a Zappi V2.1 even if you have no solar it very good for using the cheapest electricy rates that can be programed in, i have had mine now for 2 months and its saving about $40 per month by being able to use only solar that i would have exported before at $0.07 per KWH, instead of the EV import rate of $0.22 per hr off peak or $0.33 cents prkwh,
peak, hope this helps Jim
I found a picture of an UK charger and like the idea of Bring Your Own Cable. The chargers in Canada, and I suppose it is the same as in USA, have a cable attached and a lot of them were stolen for the copper, or being abused and end up unable to charge. Particular in the winter time, when the connectors will be found buried in the snow. Of course, DCFC is another story.
Hi Yellow Dog, the Zappi charger can be supplied with a 6.5 mt tethered lead or as a BYO lead option, before i up graded here in Australia, i had an BYO version, my new one is tethered and now its as easy as plugin in my phone to charge, the Sevaids above is not a home charger, but a public charger for everyone to use with the app, The small AC chargers here in Australia are mostly BYO, max power 22kw,
all others high power DC charging are fixed leads the same as Tesla superchargers, Zappi image below
For home charging, I am seeing green for those that have 220-240v AC readily available at home. Either they have pre-installed outlet for cloth dryer, etc, or that the home power supply is already at that voltage. For multi-level homes or high rise, that is another story.
