@craze1cars - Thanks for the detailed description...
The guy in the video presses the hub out first (and along with the hub comes the outer bearing race - hence the need to cut it off if re-using the hub). Then, he removes the snap ring and dust cover before pressing the bearing out of the knuckle. Given the fact that he is using a new hub anyway, couldn't he have just removed the snap ring / dust cover and pressed out the old bearing / hub in one operation?
You indicate that hubs are different, but following your methodology, the front hub is 44600-T0B-A00. When I google this, I find that this part
DOES seem to share a 'fitment' with the CRV's and HRV's:
https://www.hondapartsnow.com/genuine/honda~hub~assy~front~44600-t0b-a00.html
This is also good news because even the DIY operation could choose to be lazy like the dealer and not bother trying to saw off the bearing race.
Furthermore, it looks like you can buy a bearing / hub assembly which I assume comes with the bearing already pressed onto the hub.
You would then press the whole mess into the knuckle in one operation.
Do you agree with my assessment that there is indeed commonality with the front hubs too?
Now, for the bad news... If you look at the rear (P/N 42200-TRN-H61), it seems like a different scenario. This part is called a "Bearing Assy., RR. Hub Unit". It does not show separate parts for the bearing and the hub. I assume this means the parts are not available / sold separately? And, if you try to look for this part, there seem to be no other 'fitments' implying that this assembly is Clarity-unique.
Do you think there is a chance that these rear hubs / bearings are also common with another vehicle, but we just can't infer what the part numbers are because they are not listed separately? Or, is it just not possible to assemble and disassemble the rear bearings outside of the factory?
As you say... Very complicated. I am glad that at least the front ones are somewhat generic.
