Having a similar issue with my Clairty hearing a whooshing sound from the front and it is speed related. Took the car in for service to A01 today for the service tech to take a look. He states he doesn't hear anything, thus no action. The tech is no more than 25 years young and looked like a deer in the headlights when he put the Clarity on the lift. The dealer seemed to have so many very young techs that appear not to have a robust understanding of the Clatity. I need to find another repair facility l.
Here is what I provided Honda after I was not getting anywhere by leaving it with them.
Purchased car with around 15k miles and certified.
Noticed on the day I drove it home that it was making a pulsating droning noise with accompanying vibration.
I have driven 3 other Claritys, two new and one used and non of them make this vibration or pulsing noise.
Vibration more noticeable on smooth asphalt but is worse at higher speeds in specific ranges.
On new asphalt you can start to feel/here above 30mph.
At 67 pulsating vibration becomes very pronounced on interstate
2 pulses per second
At 80mph pulsating increases in volume and intensity but frequency slows.
1 pulse per second
Speed of pulse is inversely proportional (CVT?)
Best way I can compare the difference to the other Claritys I’ve driven is to say that above 60 others feel like riding on glass while mine feels rough. Also a much noisier ride with the vibration sound filling the cabin.
Things Honda has tried.
Replacing drivers side wheel bearing
Swapping tires from a new Clarity (no change)
Loosen and retighten engine mounts (neutralizing?)
Replacing all three engine mounts
The only thing that has appeared to change in the last 13k miles is:
At lower speeds, the vibration is still present but not as loud
At higher speeds, the vibration has become noisier with an added metal grinding pulse.
Onomatopoeia:
Above 70mph use to be
whaaoom whaaoom
now it is
Whaaoom grind whaaoom
Does not matter if the
ICE is running or not.
Can be heard and felt in all seating positions of the car at 67 and 80mph.
Switching to neutral and letting car freewheel doesn’t change it.
Pulled the fuse to the radio to attempt to eliminate the ANC with no change.
Hope this helps.
