AndysComputer
... which is a range test naturally, lol!
Any feedback greatly appreciated!
Nice — thanks for sharing this, @AndysComputer! I like the length of your route (77 miles seems doable even in the worst conditions, right?)
1) Is the 167 miles of range on a full battery that you calculated at the end based on the actual capacity or the usable capacity?
So my theory was that in ideal conditions the HVAC wouldn’t actually be running because there would be no need. So I could have used Green mode. But to be 100% sure I figured Green+ was the better option as it guaranteed that. I could have used green and simply switched off the HVAC but I wanted the blower on for fresh air.2) Did you consider selecting a mode other than Green+? I ask because while Green+ is fine for the “perfect” conditions you were driving in for this first video, because it deactivates the HVAC I don’t think it will prove to be a realistic choice for range-test drives at any other temperature — in 90F heat you’ll need to run the AC to be comfortable, and even if you were to tolerate not running the heat pump when it gets cold
Here's a YouTube video of a 2021 SE (before MINI went aero) going 177.65 miles. @AndysComputer got pretty close to matching this number. With the 4-mile increase in range MINI claims for the 2022 SE, I expect @AndysComputer will be able to exceed 180 miles.1) Is the 167 miles of range on a full battery that you calculated at the end based on the actual capacity or the usable capacity?
180 miles would be amazing, considering that a full charge in the SE's battery is equivalent to less than a gallon of gasoline! Your quest for "the right flat route" reminded me of the range record set by the first electrified car in the US: the gen-1 Honda Insight.If I found the right flat route kept my speed down (no 55-60mph roads for example) and didn't have to stop or slow down for so many red lights I could *easily* do well over 180 miles.
