I have another curve in my video discussing warm vs. cold weather range on a very consistent 260 mile commute including a fast charge.
Basically the same curve, thanks to both for the well illustrated examples.
Look forward to 21C (it will be a while yet) to enjoy those rates once again.
What I am getting now is equivalent to the 80% to 90% SOC level, tried again this morning.
Not even close to the temperature required to activate the "winter mode" pack heaters around here. I usually stop at the (right now free) 50 kW local charger just for a top up (40 minutes) and usually in the cool morning as it gets very busy (understandably) later in the day when the temperature is warmer - generally a 2 car wait. So no big deal- until they start applying a fee, supposed to happen in April 2021 and not charged by the kWh (by the minute)If you wait the battery will warm up and the charge level will be higher. On Canada models I think the battery warmer will turn on as well.
No, that is normal behavior and happens with all cars. The higher the SOC of the battery is, the higher the voltage. The amps stay the same but pack voltage increases which results in higher power. Voltage times Amp equals Power. And that's what's on the y-axis of the diagram.Good research. It is nice to see the correlation in real world data.
There is an interesting increase in charging speed at 62% SOC. Did something happen at this time?
I know a bunch of folks were (legitimately) worried about this, here is a data point from today. This is in California winter, outside temperature around ~21C, so you see it going up from 55kw to 75kw when the battery reaches 25C.
This explains a question I had raised in another thread on this forum. Thanks for posting. But if I may ask a newbie question: How does one know what the battery temperature is? Is there special instrumentation and software required?
For those who don't run any apps, the pack will pretty much be at ambient temp - unless really cold when the battery heater will cut in:This explains a question I had raised in another thread on this forum. Thanks for posting. But if I may ask a newbie question: How does one know what the battery temperature is? Is there special instrumentation and software required?
Technically the battery pack will warm up quite a bit from fast charging, I've seen it go from 10C to 30CFor those who don't run any apps, the pack will pretty much be at ambient temp - unless really cold when the battery heater will cut in:
https://www.insideevsforum.com/community/threads/kona-ev-winter-mode-defined-and-condensed.7977/
The battery pack will warm up slightly with a long drive or while charging as well. This applies for cold conditions and warm as well (above 70 F)![]()
