It definitely makes a difference, but not that big of a difference.
"most cars’ fuel efficiency peaks at
speeds from 35 to 60 miles per hour. After 60, though, fuel efficiency does drop significantly"
https://www.cbsnews.com/news/6-myths-about-gas-mileage/
Really, all I am asking is this:
How much does the range of an EV change between 35mph and 50mph?
Well, as they say: Don't believe everything you read.
I note that the article itself links to a U.S. Department of Energy (DOE) website, where we find the following graph:
So, the claim in the article you linked to, Jack, is
flat wrong when it says that fuel efficiency is essentially unchanged between 35 and 60 MPH; there is obviously a "knee" at ~50 MPH. That higher speeds force lower fuel economy is completely in line with what physics and common sense would predict, so shouldn't be surprising. The graph is unfortunately cut off at speeds lower than 40 MPH; it would be useful to see a full graph. Googling a bit, I see some startlingly contradictory graphs. However, I note that graphs labeled "
constant speed" do tend to show a similar pattern:
(source:
http://www.motortrend.com/cars/chevrolet/cruze/2012/40-mpg-compact-sedan-comparison/ )
Perhaps those graphs showing improving gasmobile fuel efficiency up to ~30 MPH, and then a plateau between 30-60 MPH, are showing fuel efficiency for an entire trip based on the
average speed... not a constant speed? If so, Jack, that may explain the misleading info in that article you pointed to.
Anyway, let's narrow the focus to
BEV energy efficiency, which seems to be the focus of Jack's interest. His question "How much does the range of an EV change between 35mph and 50mph?" is indeed an intriguing one. The efficiency curve for a BEV may well be different than it is for a gasmobile. After all, the gasmobile uses a transmission so that you can adjust gear ratios, in theory keeping the running speed of the motor within the range where it will perform the best.
Contrariwise, no production BEV has a transmission, and no doubt there are other significant differences between an EV powertrain and an
ICE powertrain, when it comes to pushing a car down the road at different speeds.
Presumably the first graph above shows the efficiency vs. speed curve for gasmobiles. What does it look like for BEVs? The following graph shows that not all BEVs are created equal:
(Source:
http://www.plugincars.com/tesla-model-s-range-exceeds-even-teslas-expecations-121253.html )
Based on the above graph, I would be very cautious of trying to make a blanket statement about energy efficiency vs. speed for BEVs in general. Perhaps most notably, those who know more than I do about EV engineering say that the Bolt EV has been engineered for maximum (or at least better) energy efficiency in stop-and-go in-city driving, whereas the Model S has been engineered for maximum (or at least better) energy efficiency on the highway.
The graph below might be instructive, altho my guess is it's likely to be a computer simulation rather than based on empirical data, because so little data on the Model 3 is available:
(source:
http://www.roperld.com/science/chevybolt.htm )
Actually, the difference between the efficiency curves for the Bolt EV and the TM3 is far less than I expected.
