We all know EVs require practically no real regular maintenance but perhaps there is one area where it pays to perform some maintenance and ideally, doing it ourselves, is the braking system:
disassembling the brake pads, cleaning and lubricating the slider pins, and this at least once a year when you live in a climate like Quebec, Canada where the weather is often cold and damp.
I've paid dearly in the past for my carelessness when I had a hybrid car and believed that the brake pads would outlive the car... Perhaps in climates that are warmer and drier but not here! I had to get everything replaced including disks, calipers, pads, etc. because everything had seized.
Does anyone know if doing this kind of preventative maintenance on a Bolt is just like on any ICE vehicle?
On my previous Camry Hybrid, it was not as simple as that and it was better left for the garage to do, requiring access to a computer to turn off certain key elements of the ABS system.
If possible, I would rather perform this maintenance work myself so I know it will be done properly and will cost MUCH less. Anyone does this also or have access to a Bolt shop manual to confirm?
Thanks,
Daniel
owner of a new 2019 Bolt LT
Thanks,
Daniel
