Passenger airbag light
  • Thread starter Thread starter su_A_ve
  • Replies Replies 6
  • Views Views 975
su_A_ve
So every other car I've ever had so far would only turn the passenger airbag light only when the weight detected was over 5-10 pounds. Working like this:
* No passenger detected or weight less than 5-10 lbs --> light OFF
* Weight detected between 10-40 lbs --> light ON
* Weight detected over 40 lbs --> light OFF
In my case, the light is on all the time unless someone's sitting. Is this 'normal'?
Ok, so I think I have a problem...
Found the online manual and it shows it should be on only if weight is detected under 65 lbs, but should not come on if there's no weight...
My reading of the text is that the light stays on if the weight is 0-65lbs. My clarity PHEV has the light on when there is nothing in the seat. I agree it is annoying and unnecessary. As you know we can’t change it.
I need glasses...
The indicator comes on to alert you that the front passenger's front airbag has been turned off. This occurs when the front passenger's weight sensors detect about 65 lbs (29 kg) or less, the weight of an infant or small child, on the seat.
Infants and small children should always ride properly restrained in a back seat.
If the front passenger's seat is empty, the passenger's front airbag will not deploy and the indicator will come on.
