K8QM
The OpenEVSE ( https://www.openevse.com/ ) Level 2 charger was mentioned in a couple of threads so I thought I would share my experiences from this week.
I received and built my OpenEVSE Advanced kit Monday evening (about 3 hours due to a wiring error as it should have been less), wall mounted it Tuesday evening (about 20 minutes) and set up the WiFi today (about 20 minutes). So far I've been through 3 charging cycles with zero problems and 2 1/2 hours instead of 12-14 is a bit of a game changer when you want to use the car in the evening after depleting the batteries during the day.
I've been somewhat agonizing about what to say about the kit aspect and I think the best advice is:
1. If you have some kit building/electrical skills and want to save some money then it's a good choice, although you might end up scratching your head at the instructions in a couple of places.
2. If you don't have some kit building/electrical skills then choose to build the kit for the learning experience not for saving money. You will probably be dazed and confused at times but if you take advantage of the OpenEVSE tech support and forums you should be successful. Note that I learned as a kid that if you get stuck, get a friend to take a look even if they don't know anything about electronics - they might notice a wiring error that you overlook since you're "sure" you followed the directions exactly.
The unit is fully featured and allows a variety of set up options. All the details can be found here: https://store.openevse.com/collections/frontpage/products/advanced-station
Note that the pre-built unit is $599 US, the complete kit (with WiFi is $489) but you can get a 10% discount coupon from a current customer - if you are going to buy, it would probably be worth mentioning it on the forum as that's how I ended up with a coupon code. With a NEMA 14-50 cable, mine was $464.85 USD including shipping.
There are several of on here with these chargers, so ask any questions and I'm sure you will get an answer.
geo
geo
