Atul Thakkar
Does any one know oil change frequency for clarity and does the computer shoes up on screen when to change, based on viscosity of oil ? Thanks
Thanks
Oil does not go bad, someone that rarely uses the gas engine is being treated the same as someone that uses for regular trips. Honda is being overly cautious or lazy.
Ditto on what Skip said. Those are the two reasons you change oil along with getting rid of the abrasive micro particles that get past the filter.Oil may not go “bad” in theory. However, it does collect condensation and unburned fuel, as well as HC’s and other chemicals. Many short trips are harder on the engine oil than long trips.
Oil is cheap. Engine rebuilds are not.
My $ 0.02,
-Skip
Oil tends to become acidic with use, acids will damage the engine components over time, changing your oil every year helps reduce damage.You guys are so 1999
You guys are so 1999.
The only reason mfg has you change the oil due to time lapse is....well there isn't except it is tradition. The wear on the engine is due to volume and type of work.
Rules of thumb are set because if they are not set some people just don't do it. The computer could give us the warning now a days and record this stuff for warranty purposes.
Spot on on the oil side of the equation.Anyone who tells you engine oil doesn’t deteriorate is wildly ignorant at best. Honda’s MM is based on a lot of real-world validation. I posted the link to the Honda R&D technical article that describes their original system development in another thread. I’ll re-post it here:
https://www.dropbox.com/s/8czldw6exebirck/Development of Engine Oil Deterioration Monitoring System.pdf?dl=0
The current systems are a bit more sophisticated, based on some material that has accompanied a new model release or two, but the basic concept remains, AFAIK.
I installed an hour meter made for a lawn mower engine that was only $5.88 delivered from eBay. On a 500 mile round trip in HV, it showed the ICE ran 2/3s of the time. I started with a full charge and ended just one bar down.Too bad there isn’t an engine clock, like there is on tractors, so you know the number of hours an engine has run. More importantly, what would be interesting is to be able to access that data to find out the average duration the engine is running. I’ve taken to using the HOV mode whenever I’m on the interstate for more than 10 miles just to get engine temperatures up to keep the oil “healthy” if there is such a thing.
That’s one more argument for an extended duration EV like the high end Teslas. Don’t have to worry about an engine, oil or other complicating issues.
