OEM tires
bmartinez028
Does anyone have experience with both the oem 17” Goodyear Eagles and Hankooks? Look for opinions on ride quality, etc between the two. We have two SEs and one of them came with the Goodyears. The other (mine) came with Pirellis(not a fan) and I switched over to the Goodyears after liking them on the first car. Since then I’ve had nothing but issues(tire pull, vibration) that hasn’t been sorted. Also seems like all the available stock for the Goodyears has manufactured dates as far back as 2021. Trying to decide whether to order two new Goodyears or just give up and get the Hankooks…
What was it about the Pirellis that disliked?
I would say that mine are wearing reasonably well (for a summer only tire, anyway), and they provided good grip when new. Downsides would be a bit of tire hum on really smooth roads at moderate speeds, and the fact that traction seems to have declined even though there's about 5 mm of tread to the wear marks still (at 22k miles). Unless something pops up to really change my mind, next spring I will likely just replace them with more P7s.
They felt spongy and seemed to exaggerate the smaller bumps in the road. They just didn’t ride all that well to me considering how soft the sidewalls were. I would get in our other SE with the Goodyears and immediately feel the smoothness. Obviously I got a bad tire or two when I bought the Goodyears for mine.
I didn't know anything about Hankook tires--or summer performance tires--when I received my Iconic SE with its 17-inch Power Spoke wheels, but I soon considered the Ventus Prime 3 tires that came on those rims to be perfect. I especially like how the Hankooks don't squeal when cornering hard in town. That silence is the perfect complement to the SE's silent acceleration.
Unfortunately, the thought of curbing the Energetic Yellow stripe around the circumference of my Power Spoke wheels caused me much angst. I put the Power Spokes in the basement and I mount them once a year to show off my MINI Electric at Drive Electric Week events.
I enjoyed the Hankook Ventus Prime 3 tires too much to try anything else. However, for a softer ride on the nasty roads near home, I bought 16-inchers and put them on some used MINI Loop Spoke rims.
The way I drive doesn't promote long tread life, so next spring I'll be buying a new set of Hankook Ventus Prime 3 tires. There are certainly stickier tires available, and tires that offer more tread life, but I've no reason to try any others.
Are you sure the 17s came with Ventus Prime 3s? I thought the 16s had those and the 17s came with the Ventus S1 Evo 3…
I put ~20,000 miles on the OEM Ventus S1 EVO 3. Loved them at first but they did get noisy and the right front developed a very strange outer edge stepped wear pattern. Alignment seemed to be OK.
At ~4 years they developed enough cracks to fail the annual safety inspection. I suspect cooler weather may had something to do with it as they had maybe 2000 miles at ~35 degree F.
I replaced them with non run flat EV Pirelli Cinturato P7 All Season Electric tire which should be better suited for colder weather. They sing quite a bit on some smooth surfaces but otherwise are quieter and feel better than the OEM Ventus until you push them. They are very good but not in the same league as the Ventus in warm and dry weather. I can get a tire spinning where I don't think I noticed with the Ventus. Two of the tires had two year old manufacturing dates, two were 4 months old. These tires have been around for years and I think Pirelli recently upgraded the tire to reduce the harmonics but seems to be using the same name. So take that with a grain of salt.
I don't notice any range difference.
As my mini SE come on 16 “ victory type rims and Hankooks summer tires I like them very much for summer but as weather in NY thru 5 month is below 45’ F I’m using all weather Nokians WRG -5Remedy the only problem the closest size for 16” rims is 205/55/16 which requires spacers/longer bolts but they excellent for slush/rain and snow /snow flake on them/ having experience with them on Subaru for 20000 miles year around they really good in my opinion.They on SE to April for now
Decided I will ditch the Goodyears after about 9k miles, skip the Hankooks and just get a set of Michelin PS5s during the upcoming Costco Michelin sale and hope for the best.
I removed the 17" Power Spoke wheels with the OEM Hankooks shortly after delivery and they are currently stored safe and sound in the garage. Replaced them with 17" wheels from Tire Rack and OEM sized Continental DWS06+ tires. I like the DWS06+ a lot better than the Hankooks...
Would you say it drastically affected efficiency? I currently average about 4.6mi/kWh with the F1s.
I would say at most a 5% decrease in efficiency. When the OEM Hankooks were on the car, I thought it felt skittish to me. With the DWS06+, the car feels more stable and planted.
I had a Tesla Model 3 Performance with the 20" Michelin Pilot Sport 4 S tires. I replaced the factory wheels with 18" forged wheels from Titan7. It was almost a 10 lb decrease in weight per wheel. Had Michelin Cross Climates installed. With that setup, I saw a 11% decrease in range. I was a little surprised by the amount. Tesla was more of an aero wheel and the Titan7s were open Y spoke wheels.
My experience was that the Hankook OEM rode a little better and gripped a little better than the Pirelli OEM. Pirellis may have had a slight edge in range, though I had the lighter/aero Powerspoke wheels with the Pirellis if that matters. I did not have the Pirellis long enough track longevity.
The Continental DWS06+ all-season is quieter and more responsive than the Hankook, with equal or better grip. Both quite good in the wet, and the DWS was pretty decent in light snow. The Hankook grip goes away quickly as the temps go to 40F or below. However I lost ~10% range going from the Hankook to the Conti.
The Conti heats up more and faster than the Hankook in autocross. They're both cooked after a couple of runs, but the Conti's smelled so foul I felt like a bad person afterward.
Hi Just fitted a set of Toyo CR1,s the latest EV ready tire in 215/55R/17, very quirt god grip and am now only using 135 whatt s per Km, mine is a 2022 Kona, it might be worth you looking at them, for the latest tire tec Jim
We have two 2024 SEs, one that came with the Hankooks and another that came with the Pirellis. Overall, the Hankooks are a little quieter and ride slightly better than the Pirellis...but I prefer the Pirellis as they have a little crisper handling and a smidgen quicker turn-in. Really though, unless driving them back-to-back (which I have done a handful of times) the differences aren't terribly noticeable.
