gadgetrants
Thanks, this is HUGE and has been bugging me for weeks. I discovered that "third" neither mode by chance, and note that the Clarity (at least, ours) will surreptitiously kick it into "neither" mode quite a bit, esp. after turning on the fan. So now I habitually:On the Climate screen, the A/C has 3 modes ("ON", "OFF", and neither). You have to explicitly turn it OFF with that button.
1. pull up the climate screen
2. make sure "OFF" is selected, and if not, select it
3. adjust the fan setting as needed
IIUC, the "neither" mode is functioning as an "AUTO" mode, i.e., when both of the "ON/OFF" modes are unselected, the climate control will honor the temperature values as thermostat settings and heat/cool the car accordingly (which is basically what you just said @MrFixit, forgive me for mansplaining). I apologize if this is discussed extensively elsewhere, but it's otherwise my first bug noted, as the "AUTO" mode light on the driver's side should kick on when this happens. grrrr.....
Sometimes the car seems to remember the "OFF" setting between drives, sometimes not. My only beef with the issue is that if I neglect to catch it, the engine turns on and I end up burning a mile or two of gas. (We can tell that AC has kicked on right away by the somewhat stale scent, and then it's a little like that scene in LA Story where they're loading the gun on the freeway, except all the drama is about getting the AC off
-Matt
