SameGuy
Yup…Weird my 2022 manual says 101 lbs ft / 140 Nm (I never checked until now). I just use the 140Nm on my Taiwanese click wrench.
“SameGuy” said:…off by a couple of foot-pounds…
Not just head size, also shear rating, thread pitch, hardness, length. Generally, lug bolts are torqued more snugly than lug nuts. Also, too many well-meaning mechanics (both shadetree as well as “licensed”) lubricate the threads to prevent corrosion, and this significantly alters the torque setting.BMW 17MM head is about 85 ft lbs, Porsche 19MM is 104 if i recall correctly. Someone once told me that there are standards for the bolt.
I had some time to finally add a few items today. I will hopefully install the black waistline tomorrow as it got delivered yesterday. It has been raining so much in SoCal the car is in need of a good detail. Waiting for window tint also until after all the rain.
Mini OEM stubby antenna, smoked lower fog lights, mini cooper license plate frame and ordered my custom vanity plate.
Nice! Did you get the OEM waistline or are you using the black tape? I have the tape on mine and it's okay, the chrome still peeks through a bit... would really like the OEM black waistline but $600 for 5-6 pieces of plastic is the only thing I can't quite justify. Tempting though LOL.
Same here, and my MA never offered it to me. I might’ve ordered it with the car if it added $10 a month to my payment, but not $600 now.would really like the OEM black waistline but $600 for 5-6 pieces of plastic is the only thing I can't quite justify. Tempting though LOL.
I know zero about this and shouldn't add,...but, somewhere I have read about lowering EVs may be a problem combined with the weight of the batteries. Anyone?
The $600 goes towards a properly designed part with OEM fit and finish, ease of install, and won't have random chrome bits showing. It is also 8 pieces if I remember right. Not saying it's cheap, but just pointing out what you're getting for the money...Nice! Did you get the OEM waistline or are you using the black tape? I have the tape on mine and it's okay, the chrome still peeks through a bit... would really like the OEM black waistline but $600 for 5-6 pieces of plastic is the only thing I can't quite justify. Tempting though LOL.
Is the OEM black waistline piano black. I've read that that colour easily collects fingerprints.
Does installation of PPF (full body) interfere with the waistline? (Eg, should the waistline be installed before PPF?)
I believe that when MINI installs the black beltline trim at the incoming port, they just throw the old trim away. So it's technically not a swap, just an add-on with additional installation expenses.What's funny is I asked my MA and he said it wasn't possible to swap out... so weird how experiences differ from dealer to dealer
The batteries in an EV are under the car so if you run over something, you run a chance of damaging the battery which may lead to a fire. If the car has been lowered, it may increase the chance of damage from running over something. If you put coilovers on the car that aren't designed for the weight of the car, you will get poor results. A heavier car than expected will mean there will be more suspension travel and thus, get lower than desired when you hit a bump in the road.
The Mini batteries are protected with a foam covering and the front has a steel bar that protects the leading edge. Also, the ST and KW coilovers are "TUV" approved which is an approval process in Europe that basically means the car is still safe after the aftermarket parts have been installed. Eibach and H&R have lowering springs that are also TUV approved. These have been designed and tested by these companies for the SE.
I trust the TUV approval process as it is much more rigorous than what the US has and I trust BMW engineers being able to design the needed protections for the battery. BMW also has been selling the i3 for about a decade so they have lots of practice on protecting the batteries.
M12 bolt 88ftlbsBMW 17MM head is about 85 ft lbs, Porsche 19MM is 104 if i recall correctly. Someone once told me that there are standards for the bolt.
Articulated ?One would think that aircraft mechanics have some fancy hydraulic torque wrench for landing gear wheel nuts, but they don’t, they also just use a BFTW.
