Tek_Freek
I am going to reiterate that the location the unit plugs into is not used when the car is charging. The car charges between 10:00pm and 9:00am. If the garage door is going to be used the car will not be plugged in. Because it's on it's way out (or coming home from a party). If I'm taking the Sorento I always unplug the Honda so my wife doesn't have to. Since we got the Honda I only use the Kia for hauling stuff so it pretty much sits there.
The lights run off pull switches. Same scenario. They won't be on if the car is plugged in. I have tested and the only thing (originally) plugged in here was the opener.
I got the chain reset so it pulls the unit hard enough to put a curve in the cable. Keeps the pressure off the plug.
A great idea from KentuckyKen. I still want something better, but this should do until then.
KentuckyKen #2.
A plastic container that held peanuts or something. (Enlarged the picture: Vanilla Gelato) No metal. No crimping. Slope keeps the cable in place.
And an extra picture for those who know the reference. A work in progress. It will be powder coated and hung on the front of our house. Most people here do cutesy suns, or Aztec figures. Not us.
BTW, see the white wire coming in from the left? The previous owner had two ceiling fans in here (you can see the end of the blade) with the wire stapled to the ceiling and a mass of electrical tape where they met - no wire nuts. A fall project will be repairing them and getting an electrician to wire them properly. You can see the plug for them just to the right of the top of the metal piece. Unplugged. It's interesting that taking the pictures and writing about the fans has got me all hot to trot to just pull it all down. I'm not going to use them until they are wired correctly.
And if you're wondering what that metal piece is hanging on it's a clothesline I set up in the garage since we are not allowed to have one outside (HOA).
KentuckyKen #2.
