This is the link on ebay which I bought it from, if you are interested. I removed the pull nylon rope since it is not necessary. It is little bit tricky to put the nuts when installing but not too hard.
Thanks. Just ordered two
Thanks , nice find and share! I just orderedThis is the link on ebay which I bought it from, if you are interested. I removed the pull nylon rope since it is not necessary. It is little bit tricky to put the nuts when installing but not too hard.
If you look at the photos, the bag has an adjustable strap with a buckle that would be used to hang it off the back of the seat. Instead, it’s long enough to loop around the floating center console.How do you attach the trash bag?
Please do and save us the struggle! I was wondering how to fasten it...thanks again!Glad you find it useful. If you have problem with installation, I will show my tip.
Just use a long think stick to hold the clip into position.Please do and save us the struggle! I was wondering how to fasten it...thanks again!
A think stick! That must be a stick that knows exactly where to position the clip behind the hole, right?Just use a long think stick to hold the clip into position.
Thanks!Just use a long think stick to hold the clip into position.
Ordered another one yesterday. I hope it arrived as soon as you get your, so I will show some pictures.
I think you meant "thin," but with one letter changed, you might have meant "thick," too. A thick stick might hold the clip against the hole better than a thin stick, but it probably takes a thin stick to get the clip where it needs to be.
Wholly trickiness, batman! Thanks for the visual, it made all the difference!I meant thin but what ever as long as you can hold the clip and put it through the square opening to reach the farther hole. Since I am not good at words, I took 1 screw off and take some pics for referenceView attachment 2270 View attachment 2271 View attachment 2272 View attachment 2273
Hi Jim,Beside the Dual channel full HD 1080 dashcam, this is the only mod on my Clarity so far: Cargo hangher and cargo net. The cargo hanger is unnoticeable when unfolding and fit exactly in 2 existing hole in the trunk, no drilling needed. Just order one to see if it works or not, will order another one to install on the right side.View attachment 2258 View attachment 2259 View attachment 2261 View attachment 2260
Since I don't want to drill my car, I hooked the bottom of the net into the corner of the black plastic piece, it firms and holds the net pretty good.Hi Jim,
I’m looking to put the cargo net in but I think I like your install better then Honda’s. Which ancher points did you use for the bottom?
Hi Jim, I'm trying to install the cargo net the way you have but I realized after I took the clips out that it wouldn't really "lock" the net hook in since I can't reach the back of the hole. Could you tell me how you did it? Thanks.Does the hanger block much of the view through the trunk window? Does it fold up when not in use? If it folds, can you see it in the trunk window when folded?
For the cargo net, I replaced the original clip with the hook ring which bought on Ebay and used the small plastic wall anchor to install it in to the holeHi Jim, I'm trying to install the cargo net the way you have but I realized after I took the clips out that it wouldn't really "lock" the net hook in since I can't reach the back of the hole. Could you tell me how you did it? Thanks.
That's awesome. Thanks! I didn't want to drill the hole nor did I feel like spending $30+ to get the rivet nut tool just for this.For the cargo net, I replaced the original clip with the hook ring which bought on Ebay and used the small plastic wall anchor to install it in to the hole
I followed your tip and used a small vice grip and it worked great! I used the clips supplied as bolts and only needed to add a washer for the larger hole. The bags perfectly reach the trunk floor. Thanks everyone!I used Vice Grip to hold the nut in place (in installing OEM cargo hook, which otherwise would require some specialized tool)
This was great. Also installed the hooks using this method--works perfectly.I used Vice Grip to hold the nut in place (in installing OEM cargo hook, which otherwise would require some specialized tool)
