The UK are to be offered just three models.
Scroll down the page to see spec's for the models described as I, II and III.
https://www.mini.co.uk/en_GB/home/range/mini-electric.html
I downloaded the Technical Data PDF file from the UK MINI site @T.C. was kind enough to link. I was confused by the AC charging info. When I read months ago that the MINI Cooper SE could handle 11kW AC charging, I switched my 9.6kW EVSE for an 11.5kW EVSE. Now I see this chart from the Technical Data sheet that says AC home charging "with wallbox" maxes out at 7.4kW, but 11kW is possible "with AC public charging."
I don't know why the MINI couldn't be designed to make full use of a single-phase 11kW EVSE, but it appears the SE's 11kW charging requires a 3-phase EVSE. My old Honda Clarity Plug-In Hybrid can handle more than 7.6kW; a newer, all-electric car should be able to better that. Darn it, the 7.4kW limitation means that if I coast into my garage with no charge it will take me an extra 42 minutes to fill 'er up.
MINI should check their horsepower conversion factors. A 135kW motor equates to 181.038 hp, not 184 hp. Will we have to wait until March for the more realistic, official EPA range numbers to be revealed?
