The biggest difference for me is that only in ECON Mode does the accelerator click point prevent the ICE from starting accidentally.The main function of ECON/normal/SPORT is to change how pressure on the accelerator is mapped to energy use and when the engine starts, although there are a few other aspects (how ACC reacts, paddle braking, and climate control, for example).
Forgot to add: I didn't see any other Clarity on the way nor in Vegas. When my friends saw the car, their first reaction was "that looks like a damn spaceship!". Couldn't be happier...
Thanks for the trip report.
Will be doing the same route later this summer....
You have made a Honda Clarity engineer somewhere smile.I have found the HV Charge option to be worthwhile when I forget to hit HV after a rest stop and run down the battery to just a few bars. It will charge up to 25/26 miles of EV range for my driving habits) and than shut off automatically. This ensures I have enough battery reserve to summit the mountain passes easily. Happy camper.
I tried that feature for the first (and hopefully last) time this past week. I was on an HV-mode trip, and just wanted to check it out for a few minutes. You are right, though. There are certain situations where it is useful, like the one you mentioned.I have found the HV Charge option to be worthwhile when I forget to hit HV after a rest stop and run down the battery to just a few bars. It will charge up to 25/26 miles of EV range for my driving habits) and than shut off automatically. This ensures I have enough battery reserve to summit the mountain passes easily. Happy camper.
I have found the HV Charge option to be worthwhile when I forget to hit HV after a rest stop and run down the battery to just a few bars...
Could add LKAS....As DesiredA simple checklist taped somewhere in view might be useful as a memory aid.
Something like...
I vote for 8.5 gallons and a spare tireMy rest stops are often not gas stations. I feel 3 more gallons capacity would have been doable and would keep more people happier. For those that like to stop at gas stations more often still can and those of us that want to drive over 400 miles between fill ups can if the tank was just a little bigger.
All in all it is not a issue. The car is worth small changes in my habits.
What sucks is you cannot just have the accelerator click point without the gimped HVAC setting. So, for me, normal or sport mode it is.The biggest difference for me is that only in ECON Mode does the accelerator click point prevent the ICE from starting accidentally.
Believe me, I was looking for another Clarity as hard as safety allowed me. No luck... But that probably helped to achieve the devastating effect seeing my car had on my friends (driving a Lexus SUV...)
Thus is my second summer with all ECON driving and I’m not experiencing a “gimpy” AC. It’s giving me all the cooling I need and all I’ve noticed is that when it reaches the set temperature it will reduce the fan speed to a setting lower than manual low.What sucks is you cannot just have the accelerator click point without the gimped HVAC setting. So, for me, normal or sport mode it is.
