Lars
What happens if one gets stuck in the winter in an EV? A very reasonable concern.
Tesla has a "Camp Mode" mode, the Kona EV has a "Utility Mode". Both shuts off most of the power drain to conserve the power in the drive battery, only providing 120V AC 'for campers' and allows the operation of climate control and seat heat.
I checked my Kona and it works as expected. In Utility mode power is provided to the Climate control as well as to the seat heaters keeping you nice and warm. There will certainly variables like the outside temp and power drain by other stuff like radio. The power drain by the climate control will vary quite a bit. It will be initially high until the set temp is reached, then the heater/heat pump will come on and turn off as needed. Based on my, very unscientific, study at 50% battery (~ 30kW) one could keep nice and comfy at 20C setting for about 30 hrs. If needed one can stretch the time by lowering the cabin temp and shot off all other electronics - like lights and the radio. At the end one may need to call a tow truck to the closest fast charger!
The attached images show the drain characteristics of the climate and electronics. Low drain by the electronics indicate radio and seat heating are OFF.
Now, if interested in EV basing by the media, check out the link below
https://insideevs.com/features/5594...-true/?utm_source=feedburner&utm_medium=email
