I’m intending to use the level one charger that came with the car. However I noticed that if I keep it plugged in to the wall socket it has an orange light that remains on indefinitely. Is that a problem? I’d rather not unplug the cable every night from the wall.
Thanks for mentioning thunderstorms. We're good about unplugging our sensitive electronics during storms but neglected the charger. It would be expensive to replace so we'll be sure not to forget from now on!We leave our level 1 charger plugged in, both to the wall outlet and the car, all the time (except during thunderstorms). I measured the power usage of the OEM charger and it’s negligible. I’ve read nothing that says we shouldn’t do that.
I can't find where either the Owners Manual or the Owners Guide discusses mounting the Control Box (as the manuals call it) on a wall. However, the Control Box does include two tabs with holes that would make mounting it on a wall possible. I agree that if it's meant to be mounted on a wall, then leaving it plugged into a wall outlet would be expected.Honda manual even suggest you mount the big adapter block on the wall for when plugged in permanently in the garage somewhere. So I'd say it's perfectly safe to do so.
I plug mine into a mechanical timer to help preserve battery life by only charging as much as I need, usually around 75%.
You can use scheduled charging on the app instead of a mechanical timer. The car won't charge beyond 80% of batt capacity anyway. So you don't really need to stop at 75%.I plug mine into a mechanical timer to help preserve battery life by only charging as much as I need, usually around 75%.
I don't do charging on a schedule. I do it when I need it.You can use scheduled charging on the app instead of a mechanical timer. The car won't charge beyond 80% of batt capacity anyway. So you don't really need to stop at 75%.
