Increased battery range after service for check engine light
  • Thread starter Thread starter PriusGeek
  • Replies Replies 8
  • Views Views 607
PriusGeek
My reliable 2018 Touring (75K miles) has slowly lost battery range over the years(~30-35 or so now), as expected. About a month ago, the check engine light came on, so I hooked up my ODB II dongle to see what was going on. It told me there was a P1DC7 and P0A7F fault related to hybrid battery deterioration. I took it into Honda and they verified the fault, but told me that Honda needed to see the fault again after they reset the code before they would replace the battery pack. (sounds like it would take a year to get one, but that's a story for another day...) Anyway, they kept the car for a full day before returning it to me, but here's what's odd: the guessometer range has dramatically increased. Where I used to se on average a 35 mile range at 100%, I now see over 50miles consistently. I figured they just erased some memory with a "factory reset" or something, but the range after a month and ~1.5K miles remains in the high 40's. The fault codes have not reappeared. What the heck could have happened? Does the clarity have some kind of secret reserve capacity the tech enabled? Is the guessometer gaslighting me? Any thoughts?
The Clarity constantly monitors the HV battery capacity. It uses some sort of algorithm that we can only make guesses about. There are certain actions (likely taken by your dealer) that can 'reset' the capacity measurement back to a factory fresh state (55 Ah). BUT - this does nothing to actually improve the battery capacity. It simply re-starts the measurement algorithm. Your car will (unfortunately very gradually) re-calculate the actual capacity, and it will return back to your former 'normal' condition. In the meantime, your range estimates will give you a false sense of 'improvement'. This process can take many weeks depending on your driving / charging routines.
You can read more about battery capacity in this thread HERE
As a point of information on the battery capacity reset, it just reset on my 2018 Clarity. This happened after I did, at the Hondalink Tech person's instruction, a full data reset for the central display/system. My Clarity could not get SOC, odometer, and location data after the HondaLink update a few weeks ago. I also did a reboot of the Android system on the central display. I had disconnected the 12V battery a couple of weeks previously to replace the 12 V battery with no reset.
I checked the battery capacity after the data reset and was at 54.9 AH after being at 49.86 in Novmber, 2024. I will wait for few charge cycles before checking again. I have found that I need to have the SOC at less than 30% and then do a full charge to 100% to get a new battery capacity reading (similar to what is needed to get the battery capacity for a laptop or a cell phone).
LeoP
@leop, thank you for this information. Unless I missed it, I don't believe that the actual cause of a battery capacity reset has ever been determined or reported on this forum. I'd rather not trigger a capacity reset if I can avoid it, so now I know what not to do when I'm tinkering with the car just for the fun of it. I realize no damage is caused, but I'd rather not have to wait weeks or months for the capacity to recalibrate back to an accurate reading.
The only downside to a reset is that there will be inaccurate readings for a period of time. One solution would be to just not monitor it for a few months. Alternatively, it could be a fascinating study to track its return to the previous level. Others may prefer to watch paint dry.
LeoP
Thank you! This explains what I'm seeing. Haven't put many miles on it since the "reset", but have an upcoming road trip that should get things back to normal.
This is exactly what happened to me this week! 42Ah to 55Ah...codes wiped by dealer.
