I just love the efficiency…
You shouldn't have to worry about turning the car off to save battery. If you're not moving you're not using any battery. Except for heating/cooling, which can be disabled with green+ mode. All of the other stuff runs off the 12 V battery and you're not going to drain that waiting for a train.
Good point. I think I knew that, but in the moment was just trying to be as conservative as possible.
This is a great thread and I appreciate seeing all of the unique range experiences. Quick question.
On the Miles/KwH reading, I know there are two options when cycling through the display using the steering wheel stalk button.
One of the KwH options changes dynamically as you drive (sometimes showing negative numbers if you’re coasting).
The other one though doesn’t seem to budge at all for me and is “stuck” on 3.8 miles/KwH.
Is that supposed to adjust automatically or is there a reset somewhere?
Again, thanks all for the great comments and information.
My assumption is that one is the instantaneous m/kwh (fun to watch, but dangerous on curvy roads) and the other is overall/trip m/kwh (which can be reset).
Did a road trip from Dayton to Columbus today, and for once, I set the cruise control to the speed limit (well, 2mph over the limit because of the BMW offset) and did my best to avoid rapid acceleration or decelerations (regen braking over friction brakes). Route was majority freeway with a 65-70 mph limit, and some light city street driving near the destination (~3 miles). A/C was on because it's the 21st century and this isn't a summer endurance test for the driver.
104.9 km travelled (65.18 mi)
94% —> 38%
56% used (16.18 kWh of 28.9 kWh cap.)
Range est.: 187.3 km (116 mi)
Eff. est.: 15.43 kWh/100km (4.03 mi/kWh)​
So I don't know, maybe the gravitational constant is different where y'all live?
Until you reset it in iDrive, just like average speed. You can also set it to “auto-reset” but I don’t know what it considers to be a completed trip, an hour off the road? Three?
Anybody have experience with an Emporia home energy monitor? Thinking of getting one, and will clamp one of the sensors to the EVSE’s circuit to get a better idea of wall-to-wheels consumption (my EVSE’s dumb ChargeLab app doesn’t show true consumption).
94% —> 38%
FWIW, the trips I have recently been describing are only about half interstate. For a trip such as you describe, I would get similar efficiency:
https://www.insideevsforum.com/comm...love-the-efficiency….18232/page-3#post-198390
IIRC, the statistics in the center display can be set to show the last 4 hours. Presumably that applies to the tablet info as well?
I have one. It's interesting for a bit, but then you tend to stop looking at it. Its power measurements are not going to be exact, because it only reads the current and makes an assumption on the voltage, but that's good enough for rough estimates.
My partner and I split household expenses, so the main use I get out of it is calculating what portion of the month's energy expenses went to charging my SE, so I can break that out separately and not have her pay for it.
If you hold the top button on the driver's display, a menu will pop up. You can reset the avg mi/kWh from this menu.
I set mine as a brand new calculation on each journey so I always know what the efficiency is at the very moment.
94% —> 38%
Did almost exactly the same trip again on Wednesday, only this time I drove like I normally do (~10mph over the limit).
105.3 km travelled (65.43 mi) ... away
100% —> 37%
63% used (18.21 kWh of 28.9 kWh cap.)
Range est.: 167.1 km (104 mi)
Eff. est.: 17.29 kWh/100km (3.59 mi/kWh)​
105.8 km travelled (65.74 mi) ... return
88% —> 25%
Range est.: 167.9 km (104 mi)
Eff. est.: 17.21 kWh/100km (3.61 mi/kWh)​
Got my worst tank result since the sub-freezing temperatures of early spring. Didn’t bother doing the math, but travelled 101 km and it’s showing 20% remaining. That’s because at work I park in an open lot, and it has been sunny and upper 80s all week. Even though I use a windshield shade and two pop-in reflectors in the sunroof, I’ve used a half hour of cabin preconditioning before returning to my car every single day this week. At 4½¢ per kWh I’m ok with enjoying the comfort features offered by my car!
100% —> 37%
88% —> 25%
For the benefit of any non-owners who might read this thread, those numbers resonate with me.
Semi-rhetorical question: should that use of the energy stored in the battery really count against the range?
If you idled an ICE vehicle while running the A/C before starting a trip, would you count that against your MPG? (I assume most people wouldn't.)
I would. In this instance, cooling the vehicle to make it more pleasant is definitely part of the "cost" of the trip. Satisfying one's own desires also include going speeds in excess of 70mph, wonderfully rapid acceleration from a stop, and getting the most out of roundabouts.
for the record, I spend most of my driving in green+ mode. Still loving every drive.
