It should work. Clarity's trunk is not as heavy as a hatchback's trunk.Can't you do it with just one hydraulic cylinder that's larger?
Agreed its all way too slow. Another slow thing in this car and every other car I've ever been in are the power seats. Why do they have to be so slow? That was one more reason for me to get the base model to avoid them, I can just slide from my wife's setting in an instant and be on my way.
I found this advice on a Civic site in response to similar complaints, "The Quick Service guys said that to do a hard reset of the infotainment system, you need to hold down the dimmer switch while pressing the audio off and menu buttons at the same time. Hold them down for a long time, until the screen asks if you want to reboot. (You may have to let go and hold them down more than once.) Select yes, and the system will reboot. That fixed my problem! The guy said that they recommend doing this every six months or so, since a lot of data can cache in these systems, and the reboot clears it. Hope this is useful."
I haven't tried it yet so no guarantees.
Who'd have thought we would have to ask for this?I would like an Econ heat setting that will use whatever engine coolant heat is available to warm the cabin without the electric heat unless I really want electric heat. I believe this will increase range and comfort.
Oh yeah! I like this.I've said this one before but permit one to select HV and leave it in HV mode across restarts. I'd just make the setting (whatever it is) persistent. Users could still opt for what they like. If you like and use EV exclusively so be it. Select EV and leave that. If you on long trip and want HV for each start for a few days, let the car automatically stay in HV.
-Dan
Try long pressing the Neutral button with no pedal input. Works for me but I never use it.Oh yeah! I like this.
I would love to be able to keep it in ev mode.
I don't like the way they did the various drive modes. The only way to get sticky regen braking is in sport mode, but sport mode also changes the mapping of the accelerator pedal, and then I often inadvertently kick the ICE on.
Personally I think changing the mapping of the go pedal is always a stupid idea in any car. I want to have muscle memory that tells me how much go I get for a pedal movement. Changing it up with eco or normal or sport, is silly, it doesn't make the car any more powerful or any more economical it just makes you move your foot more or less. Instead the modes should be EV, HV, and a toggle between regen braking sticky or not.
Someone talked about putting it in neutral to coast. I have tried and it would not let me do that while moving.
We didn't drive our Clarity for 2 weeks last winter and the rotors accumulated so much rust that no amount of heavy braking (and attendant tire wear) could fix it. Our dealer had to clean the rotors to cure the "swish-swish-swish" sound always present when not using the brakes. I hated how it disturbed the normally quiet EV travel.I use N on a downhill to clean the rust off my rotors once in a while.
