So I am having issues charing my brand new Ford Mustang Mach-e (MME) AWD extended range. Here is my situation. Let me know your thoughts and why this may be happening or any suggestions.
1). 240V Nema 1450 Outlet
+Been successfully charging my Tesla Model 3 for two years with no issues at all.
+On 2/25 trained EV Electrician has confirmed that the 240V outlet tests fine at the plug. It is on a 50-amp breaker and includes red/black hot and white netural (6 gauge cable) and a green ground with 10 gauge. Everything also tested perfect at the breaker panel. Again, I have had NO issue with other vehicles.
2). Tested both a Juice Box Pro 40 (previous gen) and the included Ford Mobile Charger with the NEMA 1450 adapter
+When connected to the car, within 2 seconds an audible click can be heard from the charger (especially on the Ford Mobile Charger and when it first connected to the car a very tiny red LED on Ford Mobile Charger with Blue LEDS is seen and after a split second it turns all blue).
+Charging Port on vehicle shows white LEDs ring lit up based on the charge level. After about 30 seconds, charge port LEDs turn off.
+With doors locked and car off, no charge is passing through the 240V (works fine for 110)
+Through the Sync infotainment sytem in the car and Ford Pass App, location is set to manual charge when plugged in.
Now, here is where it gets interesting. If I power on the car, it starts to charge with the 240V but only at less then 2 Amps and less then 1 (KW). If I stay in the car now, it keeps charging at this snail pass rate (which is an issue). However, once I exit the car, after a 15-30 seconds it drops back down to 0 currents. Same is true if I unplug and replug the charger when outside the car. It is like the MME internal charger is telling the chargers not to charge when given an L2 charge. I have confirmed no charging schedules or departure schedules exist in the MME or Ford Pass App. It is set to charge now.
I find it really hard to believe this is an issue with my electric. Any thoughts or suggestions? I feel like I have a $60K paper weight in the garage.
