I meant the state of charge of the HV battery. If you had zero EV miles left, then the battery was fully depleted.
Here's what I do when driving the Clarity:
If I will be taking a trip where I know I will be driving more miles than the HV battery will provide, I will start the trip in EV mode and drive about 10 miles in EV. (The reason to start the trip in EV mode is to get some room in the battery for regen energy to go back into the battery when you go down hills or decelerate - 8 to 10 miles will give you about 25% of the battery available for this). Then switch to HV mode. This will start the gasoline engine (again with the HV battery at near 75% charge). When I am within 25-30 miles to where I will charge the car, I will switch back to EV mode and deplete the battery to near zero by the time I arrive, aiming to still be running in EV mode at the time I reach the destination. If it looks like I switched back to EV too soon and I won't have enough battery to make it, I will switch back to HV mode, run a few more miles on gas, then switch back to EV and complete the trip. You might "waste" a couple of miles of EV mode (arrive with a couple of miles still on the battery) doing this, but you won't have the loud gasoline engine operation, and you will have adequate power available if you need to pass a car or climb a small hill at the end of the drive.
The goal is to not operate the gas engine with a depleted or nearly depleted HV battery.
Hope that helps.
Robert
