Interesting. Only draws 8 Amps, so I could see it not running down the 12V in the short term. And less than 4 Oz per hour of diesel, so it’s cheap heat that doesn’t reduce your EV range.
How did you mount it? Cabin, trunk or under hood? And how did you run the air intake and exhaust if not external. And if external, where did you route the air ducts? I ask because I’m still trying to find the best way to route cabling through the firewall.
Of course, 8 Amps at 12V is 96 Watts; I question how effectively that can actually heat the car. From what I've Googled, electric car resistance heaters (presumably including the Clarity) are in the range of 4000-8000 Watts. Running the car's climate control such that it heats for 1/40th of your drive would be equivalent. Now, if the low wattage heater provides enough comfort that the driver doesn't feel the need to raise the car's ambient temp to, say, 65-70 degrees, then it is indeed a major savings. Similarly, seat heaters seem to be around 50 watts max, so if they reduce the desire to heat the entire car it's a win.
Of course, the "automatic" climate control systems that focus on ambient temperature make this harder to manage, but that's for another thread...
