Grizzl-e classic EVSE hacking
  • Thread starter Thread starter Muusezap
  • Replies Replies 7
  • Views Views 36
Muusezap
Has anyone dumped the firmware, reverse engineered the OCCP esp board, or otherwise poked at the grizzl-e classic? I want to build a board to toss my station of my zigbee mesh but I need to know more about host that connector works and I feel like by now someone has already done this.
I should have been more precise. I own 3 JuiceBox 40 Pro then the company that bought them destroyed the servers and ended useful support. This meant the server based configuration software was buggered.
OpenEVSE offers a controller board and open source code. Swapping out the controller gave me full access to the operating software and via WiFi, configuration of the charger. The power cables and housing remained the same. Plus I have source code access to the software.
I bought two controller boards, $100 each, and operated one with the second board a spare. I gave the operating one to my brother when he bought my 2017 BMW i3-REx.
You might find the OpenEVSE “brain transplant” easier than modification to the original part. It is well worth asking if your desired functionality is part of their future plans?
GOOD LUCK!
I don’t have the original part. I’m looking at building one. From what little I’m finding, well, there is considerable overlap between open EVSE and grizzly, the communications between grizzly’s Wi-Fi module is not the same as the method open EVSE uses
OpenEVSE has available source code and ‘difficult’ if somewhat readable schematics.
If it were my project, I would start with a trusted zigbee or zwave microcontroller and then do your own glue logic for J1772. In effect my JuiceBox 40 Pro just provided power connectors and housing for the OpenEVSE controller and software.
It isn’t clear why zigbee or zwave communications adds value. Perhaps build a bridge box for WiFi to the z-networks would be another approach.
Zigbee, zwave and thread are mesh networks. It’s easier to reach my detached garage with than making WiFi reach which can be done but it’s overkill for what I’m trying to do.
Again, I am not using an openEVSE. I don’t have that equipment.
