Green charge light not coming on.
  • Thread starter Thread starter Sthomasa
  • Replies Replies 9
  • Views Views 5K
Sthomasa
After a charge point charge, suddenly my green light will not light. Drove awhile and opening ev door gets me no light at all.
Am i doing something wrong? Or something blown?
Trien fob button and dash button. 23 mile range left.
Help?
Help?
Plug in your Honda EVSE for a brief time, then try the CP EVSE again. Others with your issue have had that reset the charger.
The other possibility is your car needs the software update for charging problems. If it’s a 2018 does it have all the latest updates.
Early 2019. 1500s sn . Love this car! Near perfect and just the right amount of tech to make it very interesting. Refuse to RTFManual. Guess i enjoy the puzzle of this amazing car. Like a murder mystery where i always done it and didnt know i done it.
Have you set up a scheduled charge? Your vehicle won't charge outside that window no matter what charger you are using unless you override on the app.
Also, when your car is plugged in and the green light is not on, check the app to see if it says you are plugged in or if it does not even recognize the connection.
I've experienced this a couple of times, and the cause was the charge handle as not completely seated (you'll hear the latch click). Charging stations light switched to "Connected", but green light on the Clarity did not light and charge session could not be initiated.
Usually when i open charge door, green light blinks. Then a connection can be made.
At a public station, i over ride scheduled charge by holding fob button.
But yesterday, nothing lit, no response from any thing, no ability to charge. I checked over a few hours.
I drove for a few hv hours, came home and opened ev door and light blinked and later took scheduled charge.
Dealer software update being checked today.
Sthomasa, I've had variations of this problem a few times myself- and luckily always found a solution. There's a number of previous threads about how Chargepoint level 2 charging sometimes seems to confuse the onboard charging system of the Clarity (particularly if there are power fluctuations), and afterwards the Clarity seems to quit trusting the Chargepoint and won't let it charge.
The quickest potential solution is to do exactly what Sandroad suggested; try charging with the supplied Honda level-1 charger. If it's the "charger trust" issue described above, that should not only turn the green light on, but also allow you to use the Chargepoint again. If you're not getting a green light with the Honda-supplied charger (and assuming your battery is not already fully charged) then there's something more serious going on.
I have a 2019 Clarity for a few weeks and I already had the same problem a few times with Charge point. Really frustrated when it happens!
