weave
I do a lot of long distance travel, hence in HV mode. It has baffled me that sometimes the engine will stop when I coast or slow down, and other times it keeps running and seems to never shut off unless I come to a complete stop.
Some observations after a lot of miles:
So really it goes into some short periods of HV charge mode when battery gets too low below that set point. Hence why I think HV charge mode being used on purpose and then use EV mode isn't THAT inefficient. You're just basically taking a bunch of little charge/EV times and making it into a longer charge then EV time. It all washes out in the end as far as gas mileage goes.
I'm going to keep trying to look for patterns the more I drive. One thing that bugs me is the 2 mile deficit measurement. I would think if it is using a value to determine when to change behavior, it'd be measured in kilometers, not miles.
Basically the car is controlled by a computer, so it doesn't have a mind of its own. It's operating on rules. So when it's behavior changes, then something trigged it. That's what I'm trying to figure out. So any other observations you have are appreciated.
Also one more observation. If I preheat the cabin from a L2 charger then drive almost right away in HV mode, it cycles the engine on and off almost right away instead of waiting the ~10 minutes to warm it up. Hence I think preheating the cabin is also warming up the ICE ahead of time, meaning less stress to engine starting when cold.
So far all theories but still testing to see how often and reliably I can reproduce them all.
- Speeds above about 70 tend to drain the battery more as the car tries to use battery power to supplement the direct drive -- if it's on. Especially on a slight incline. I've watched my EV miles drop quite a bit when going over 70. Also direct drive engages a lot less on speeds over 70 from my observations.
- HV mode seems to want to keep the battery charged up to where it was engaged.
- If I keep the battery deficit from dropping below about 2 miles of EV range, the system will cycle the engine on and off while driving, like if I coast or have very light acceleration.
- Once the HV mode drops EV range by about 2 miles, it goes into a mode where it won't stop the engine unless you come to a stop. It wants to charge the battery back up.
- However, the recharge aggressiveness seems to slow down once it gets within about a mile of original level when HV mode started, which means likelihood of engine shutting off at highway speed diminishes greatly once you hit that ~2 mile deficit threshold.
- If you have a lot of downhill and recharging and the battery level goes above what it was when HV mode was engaged, it gets far more aggressive at using the battery, shutting the engine down and pushing that blue bar fairly high so you an even keep up some speed on a flat road with the engine off.
