EV Watchdog App
Happy to announce the EV Watchdog Free App (Android only) has just been published.
Following the PHEV Watchdog App (which supports the Outlander PHEV, Kia Niro PHEV, Kia Optima PHEV and Hyundai Ioniq PHEV) and after some requests I've decided to create a new Android (only) monitoring App for Kia and Hyundai EV models.
Watchdog is a complete monitoring App, it does not only extract and display info provided by the car systems in real time but creates more stats and analysis and keeps track of everything by storing historical data in it's internal database.
Here a couple of screenshots of the live monitoring screens (or where you see the info while driving)
The App keeps track in a list of the battery condition (changes in SoH and SoC). And you'll get one card for every changes seen (screen on the left). From each card (one tap) you'll have access to the details of the recorded state (right screen).
You can get the App from playstore here:
https://play.google.com/store/apps/details?id=ev.watchdog
And be sure to check the FAQ on the website:
https://evwatchdog.net/help/faq.php
Also if you're in facebook please join the Facebook group for the App:
https://www.facebook.com/groups/ev.watchdog
Enjoy!
Yeah, you have some things to look at here. I tried to change the system units to Imperial and the app kept displaying in metric. Also, it is insanely annoying that everytime I make a setting change I have to restart the application. You need to make that more seemless. The app also doesn't make it clear that it established a connection to the ODBII reader. It should display that more obviously somewhere.
On the plus side, I did get it to display the SoH of my Niro's batter (US spec). After about 3700 miles, it still says 100.0% health. Not sure if that's accurate or not, however.
I want to add that your app is unstable on my phone (Galaxy S10e). When I press Odometer it is supposed to toggle through a few options (range, ODO and one other), it crashes every time.
More bugs found: if you set the app up to automatically start a session when the app starts and it can't communicate with your car (because its out of range or not on), then the app goes into an endless loop spamming a message it can't establish communication to the car. When this happens, I can't get to settings to turn off the automatic starting. In fact, getting to settings is not easy at all to do in this app.
if you are android, you should be able to delete the app data, hopefully that will clear the autostart setting.... if you have ios, I don't know, but there should be a way to do it.
Greg
This app is incredibly unstable for me. It crashes when trying to flip through the Odometer/Range setting, it seems to crash randomly. I am going to uninstall it until the author can get it working right.
OK, that's v0.4 beta so please do not expect to be perfect.
Already fixed the odometer/range change of units crash for the next release.
Looking at the system of units bug and should be OK for the next release.
For the OBD2 connection status look for the icon in the top right corner.
Not supposed to launch the App while you are away from your car or the car is off, so at this moment noted but not on my priority list.
Same for the "restart app after settings change" most changes don't require it so don't see it as real problem.
Thanks for the feedback I do appreciate it.
Since the App is provided at no cost I'm really not after good reviews but I do care about the troubles/opinions of the users.
I'm sorry if the App is not up to your standards and if you feel it's not working for you please feel free to uninstall and forget.
I was expecting the app to behave better. If this is a beta, I can understand that, but I didn't see anywhere in this thread (until your last post) that it is a beta. I will wait until it matures more and give it another try.
On the positive side, I do like how much information it exposes. That's very handy.
v1.1 now available: https://play.google.com/store/apps/details?id=ev.watchdog
  • Fixed starting live data not cancelling when no communication (Build 2021JAN08)
  • Fixed landscape orientation screen issues (Build 2021JAN08)
  • Fixed kWh cost parsing (Build 2021JAN08)
  • Fixed About Screen not displaying right (Build 2021JAN08)
  • Several other fixes and adjustments (Build 2021JAN08)
FAQ here: http://evwatchdog.net/help/faq.php
And be sure to join the dedicated fb group where I share all the developments:
v1.3 now available in two versions:
The existent free ad based version: https://play.google.com/store/apps/details?id=ev.watchdog
And a new premium paid version: https://play.google.com/store/apps/details?id=ev.watchdog.full
List of extended features of the premium version here: https://evwatchdog.net/app.php
Changes for v1.3
Free version:
  • Minimum supported API level raised to 16 (Android 4.1 Jelly Bean)
  • App's folder migration to Download folder (required for targeting API30)
  • Added file debugging
  • Added autostart prompt options
  • Fixed negative temperature values
  • Fixed freezing when starting live data from the cells chart screen
  • Several other bug fixes ands adjustments
  • Premium version, all the above plus:
  • Added notifications for cell voltage
  • Added average line for charts
  • Added Charge X Time and Temperature X Time charts
  • Fixed linear distance for near by stations
FB group: https://www.facebook.com/groups/ev.watchdog/
Website: https://evwatchdog.net
FAQ: https://evwatchdog.net/help/faq.php
v1.4 now available
Changes for v1.4
  • fixed cost for kwh not parsing
  • fixed max temperature display (was showing min)
  • fixed pack size (39/64kWh) recognition for Kauai/Niro
  • upgraded db to v5
  • added edit cost kwh for trip card
  • added set cost kwh backwards for settings option
  • several other fixes and adjustments
  • added NearBy screen autoupdate option
  • added sync data option
Biggest change is for the premium version where the sync data option is now available.
In order to sync data to the web server do as follows (see attached screens):
1. activate the option in the settings menu,
2. agree data uploading,
3. go to the website sign up page (blue link in the dialog box) and register there providing your NetId code that was copied to the clipboard by the App.
4. verify your email.
Then from the App make sure you are connected to a data network and hit the "Sync Now" option in the App's menu to force to send the data on normal usage this is actually not necessary as the App will try to sync several times by itself during operation).
Now log in to the website: https://evwatchdog.net, fill any missing info in your profile, read and agree with the terms and you're in. You should see all your data there plus other interesting graphical and tabular analysis.
FAQ here: EV Watchdog Android monitoring App - FAQ
And be sure to join the dedicated fb group where I share all the developments: Facebook Groups
v1.5 now available
  • Changed capacity calculation for battery card (now uses nominal voltage)
  • Upgraded db to v6
  • Added "Go!" button in charging station details for Maps*
  • Added charging mode
  • Added glide and regenerative braking distance
  • Several fixes and adjustment for charts screen*
  • Several other minor bug fixes and adjustments
* premium version only
Added charging mode which shows remaining time (to 100%), charged kWh and instant charging kW
dog_net_27-jpg.6706
New "Go!" button in the charging station details which will open Maps and set destination
More info on the website: https://evwatchdog.net
Download: https://evwatchdog.net/app.php
