EV ownership is full of acronyms and terms that can discourage new or prospective owners from making the jump from ICE into an EV. This list will give you a leg up on learning about the cars, how they operate, and help define common phrases used on the forums.
EV Acronyms
1
1PD
- 1 Pedal Driving
- see also: One Pedal Driving
A
B
Battery Chemistry
- Batteries are built from different elements such as lead-acid (Pb), Lithium Iron Phosphate (LiFePo4), Nickel Manganese Cobalt (NMC), Nickel Manganese Cobalt Aluminum (NMCA) among others and uses a chemical reaction between two electrodes (anode and cathode), separated by an electrolyte, to store and release energy as electricity
BEV
- Battery Electric Vehicle
Bi-Directional Charging
BMS
- Battery Management System
- Used to control charge and discharge to the battery to protect it and balance the cells
C
CCS
- Combined Charging System
- Offering a standard J1772 plug with 2 additional DC connection points to enable Level 3 fast DC charging
- Often called the SAE Combo
- CCS Type 1 - more common in the North America and Japan
- CCS Type 2 - more common in Europe and Australia
- Both CCS Type 1 and CCS Type 2 connectors are designed to be backwards compatible with their respective AC charging connectors.
CHAdeMO
- Level 3 charging port
- Bi-directional for V2G connectivity
Charging Levels
- Level 1 - Generally 120 AC
- Standard home outlet, 5-10 miles per hour of charge (varies by model)
- 1.3-2.4 kW
- Level 2 - Generally 240 AC
- Most home EV charging systems provide this level, and offer about 30 miles of range per hour (varies by model)
- 3-20 kW
- Level 3 - DC, Voltage Varies
- 100-200 miles range per hour charge (varies by model and amp)
- 50-350 kW
Control Pilot
- The Control Pilot (abbreviated as CP or EVCP) signal enables basic communication between the EVSE (charger) and EV (electrical vehicle). This is a standard defined in IEC standard 61851-1
- This signal is a pulse width that sends information about max charge rates to the EV and signals like charge complete back to the EVSE.
- There are 6 main statuses:
- A - EV Disconnected - +12V signal
- B - EV Connected - +9V signal
- C - EV Charging - +6V signal
- D - EV Charge, Ventilation Required - +3V signal
- E - Error Condition - 0V signal
- F - Fault Condition - -12V signal
D
E
EV
- Electric Vehicle
EVSE
- Electric Vehicle Supply Equipment
- This is your charging equipment, cables, etc
F
FCEV
- Fuel Cell Electric Vehicle
- Generally powered by hydrogen fuel cells to produce electricity for the electric motor(s)
G
GBT
- Charger connection type mostly found in China and Eastern Europe
GoM
- Guess o Meter
- Estimate of range left based on historic driving patterns and various sensor readings
H
HEV
- Hybrid Electric Vehicle
- A Vehicle that usually has a gasoline engine and an electric motor, but lacks plugin charging and relies mostly on regenerative braking the charge a small battery bank
I
J
J1772
- Standard round plug for Level 1 and Level 2 charging
- Sometimes called the "J-Plug"
J34002
- NACS plug type
- see also NACS
K
L
LiFePo4
- Lithium Iron Phosphate Battery type
- see also: Battery Chemistry
M
Mennekes Type 2
- Common European Charger connector type
- see CCS Type 2 for Fast Charge
MPGe
- Miles per Gallon Equivalent
- Used to measure efficiency in comparison to an ICE vehicle. 1 Gallon of gasoline is 33.7 kW
N
NACS
NMC
- Nickel Manganese Cobalt Battery type
NMCA
- Nickel Manganese Cobalt Aluminum Battery type
O
One Pedal Driving
- Some EVs have a setting to allow the accelerator pedal control both acceleration and deceleration by leveraging regen braking when the throttle is reduced
- Sometimes abbreviated as 1PD
P
Pb
- Lead Acid Battery type
PHEV
- Plug-in Hybrid Electric Vehicle
Plug Type
- The style of connector from the charger to your vehicle.
- See: EV Plug Types: A Guide to Types of EV Charging Plugs & Uses
Proximity Pilot
- A safety feature in EV charging that prevents the car from being driven while the charging cable is connected and confirms a proper connection before charging begins
- Controls a 'soft' shut down to reduce the chance of electric shock or short circuits when disconnecting cables
Q
R
Range
- How far you are able to travel on the available energy in the battery and average MPGe
REEV
- Range Extended Electric Vehicle
- These vehicles tend to have a 'generator' engine running on gasoline or diesel fuel which charges the battery bank to run the electric motor(s)
S
SAE Combo
- See also: CCS (combined charging system)
SOC
- State of Charge
- The battery's fullness from 0 to 100 (where 0 is empty/dead and 100 is full capacity)
SSB
- Solid State Battery
T
U
V
V2G
- Vehicle to Grid
- Allows your battery to communicate with the power company to control charge rates
- see also: Bi-Directional Charging
V2H
- Vehicle to Home
- Allows your car battery to act as a home battery back up system to power your home in a power outage
V2L
- Vehicle to Load
- Allows your car battery to power electronics directly via invertor to AC 120 or can sometimes be used to power/charge another EV directly
Vampire Drain
- The loss of range when sitting/parked, usually a percent or two a day
Y
X
Y
Z
