Hi
@imjohn-smith and welcome. That is a really wide topic and much has been written on the subject. The specifics depends on the vehicle, the country, and sometimes the part of the country one is driving in. If you have more specific questions someone here will answer them. There are lots of articles here on Inside EV's on the subject.
Initially I will give a general answer. There are two basic types of charging stations based on electricity supply.
DCFC - Direct Current Fast Charging (DCFC) is type of charging station that operates on direct current. DCFC can deliver the highest charging speeds. Where compatibility issues may occur is when the vehicle has a different charging port compared to the charging station available plug(s). Different countries/continents have different plug standards. In the US there are three basic DCFC plugs. Tesla, until recently, has had a proprietary plug on their vehicles and charging equipment. That plug more recently has been renamed the North American Charging Standard (
NACS) and recently has been the basis for the adoption of the J3400 standard and a movement towards that as a single plug standard. Most of all other EV's for sale in the US and equipped for DCFC have a port called the Combined Charging System (
CCS1), except currently the Nissan Leaf. The Leaf has a separate plug referred to as CHAdeMo. Another potential (though usually temporary) incompatibility is when the vehicle software and charging station software do not speak the same 'language' or have different interpretations of the standard. Sometimes it is a brief hiccup in charging that requires restarting the session and sometimes the vehicle will not charge. DCFC delivers the fastest charging speeds and that maximum speed varies by the capabilities of the equipment at a charging station location, the voltage of the vehicle (300+ volts or more which varies based on the high-voltage battery state of charge), temperatures, and the supply of electricity to the location. Because of the high power requirements and more expenmsiove equipment, DCFC is typically used either in public charging or a commercial fleet location.
Level 1 or 2 - Operates on alternating current. Level 2 is alternating current typically in the 208-277 volts range and is used for home appliances like a hot water heater, clothes dryer, or a range. The charging station operates with similar voltage and typically delivers the current at a fairly constant voltage. Level 2 recharging typically takes a few hours to overnight depending on the capacity and initial state of charge of the high-voltage battery. Level 1 in the US is based on 110/120 alternating current and many vehicles either are sold with or one can buy charging equipment to charge the vehicle at home, and is the slowest form of recharging, taking overnight or longer. Again there are two types of plugs which can charge at either Level 1 or Level 2. Tesla and the J1772 plug found on other vehicles.
